Results 1 to 8 of 8
Thread: 1998 E39 M62 Wheel Speed Sensors
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    While doing rear brakes I discovered both the brake pad sensor and the rear wheel speed sensor needed to be replaced. Brake pad sensor no problem, rear wheel speed sensor however was spliced- that's correct I said spliced. Question: do those rear wheel speed sensors meet somewhere in the middle say above the differential so that I can unplug it from there and then plug it into the new one I have, or what's the best way to tackle this situation? Yes I have a brand new one...
    TIA
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    San Jose, CA
    1997 BMW 540i 6 speed
    Does the new sensor have a connector on the end?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Yeah there's supposed to be a connector that sits in a little plastic box in each wheelwell. You open the plastic box and the connector pops out of that, then you disconnect, and, voila. Same box that the brake sensor connector snaps into on the wheel that has it.
    If you're missing that body-side connector... it should be an easy junkyard pickup, cut out a nice long length, then re-do a high quality fresh splice and put the connector back in. You could also buy the factory connector socket depending on which solution is easier/faster/cheaper.
    I was gonna link the pic here for the shot of the connector box, but the whole post is probably helpful. Aside from the spelling mistakes.
    https://www.bimmerforums.com/forum/s...Sensor-Replace
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Thanks guys, yes the new wheel speed sensor has a new connector like you would expect brand new... just getting back to this but I understand that that piece is hardwired into the harness. I don't know if a junkyard is going to be that easy of a solution but I'm going to exhaust all avenues. I was hoping there's a connector under there somewhere where I could just buy a whole new piece, and then bring it out and plug in the new outer cable to it. I'll check out your post GG as well. I may just have to modify it and splice it with wire nuts and electrical tape or heat shrink and then electrical tape or not. Some f****** nincompoop probably couldn't get the old one apart and just cut it!
    UUUUUUUUUUUURGH!!!
    Sent from my LG-V930 using Tapatalk
    Mar 2010
    Dude. No wire nuts. That makes you no better than loserboy who screwed the car up for you.
    Two avenues both legit.
    QUALITY (not crap hardware store) butt splices. Or. Solder.
    Either way heat shrink over then optionally can RTV the ends for extra sealyness.
    Buy an assortment of these and a decent but affordable ratchet crimp tool and you won’t be a crap-splice-loser anymore.
    https://www.delcity.net/store/Perma!...12022.h_812023
    Doing a real nice splice / repair job is satisfying and having the gear means from now on your wiring work will be 100x easier and better.
    2003 M3CicM6 TiAg
    Former:
    Thanks Duuude. What size [guage] is that speed sensor wire ya think?
    Mar 2010
    Quote Originally Posted by 300kplus View Post
    Dude you SO LUCKY a dudebro that I am so willing to use my amazing google-fu for you. I can't explain it really, just my amazing generosity and strength of character.
    WDS says .5mm^2 wire
    http://www.bmw-planet.net/diagrams/r...000008708.svgz
    Which internet says is roughly 20AWG.
    Now my suggesto to you would be, since you're paying shipping already, order one min-qty each package of red/blue/yellow butt splices, then order a ratchet crimper...
    https://www.ebay.com/sch/i.html?_nkw...+tool&_sacat=0
    ...and you'll be set next time regardless of the wire size. Maybe order a few more of the reds since it looks like you'll use the reds on this project.
    Another pro-tip is to offset the splice for the 2 wires so the individual wire splices aren't side by side.
    Last edited by geargrinder; 08-14-2018 at 08:30 AM. Reason: browserfarted and double posted
    2003 M3CicM6 TiAg
    Former:
    Now my suggesto to you would be, since you're paying shipping already, order one min-qty package of red/blue/yellow butt splices, then order a ratchet crimper...
    DUDE! BRO! DUDEBRO-You da man! Will do. As always, much appreciated!
  1. E39 Wheel Speed Sensor Replacement
    By Teuobk in forum 1996 - 2003 (E39)
    Last Post: 07-13-2017, 08:08 PM
  2. new e39 wheel speed sensor problem
    By philly905 in forum 1996 - 2003 (E39)
    Last Post: 12-18-2014, 08:59 PM
  3. E39 WTB: Brake light switch and rear wheel speed sensor
    By Lavalamp in forum BMW Parts Wanted
    Last Post: 11-28-2011, 11:13 PM
  4. Another E39 ABS/ASC light wheel speed sensor thread
    By JohnnyRedd in forum 1996 - 2003 (E39)
    Last Post: 06-20-2010, 06:41 PM
  5. Rear wheel speed sensor E39 identification
    By PhotoDoug in forum 1996 - 2003 (E39)
    Last Post: 03-26-2010, 03:55 PM
