Results 1 to 4 of 4
Thread: Engine won't shut down
    Oct 2017
    Illinois
    1979 635csi
    After taking off my sterring wheel and taking out my instrument cluster today and reinstalling when I turned key to off position the engine didn't turn off. I jostled the key in the switch and reached behind the cluster and hit those wires too. Switch bad and just a coincidence? Did i pinch something? Thoughts?
    Aug 2008
    Sydney Australa
    1x633, 1x E3 2 DR Racer
    It does sound like you pinched something. I'd repeat the out and back in process and see if the constant running issue remains.
    1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
    1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
    Oct 2017
    Illinois
    1979 635csi
    Seems to have cleared itself for now.
    Sep 2012
    Imperial Beach, CA
    1985 635csi
    I'd suggest replacing the ignition switch. I had the same issue, turned the key to off, kept on running.. Pull the cover off the steering column, and it's exposed for replacement if I recall. Off the top of my head, around $100 give or take.
  1. engine won't shut off.
    By oclee118 in forum 2002
    Last Post: 05-04-2010, 02:48 AM
  2. Alarm won't shut down until I start the car.
    By Balthazarr in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2009, 03:33 PM
  3. Replies: 13
    Last Post: 01-25-2008, 01:36 PM
  4. Car shut down while driving and won't start
    By kmwheel in forum 1991 - 1999 (E36)
    Last Post: 12-20-2004, 02:45 PM
  5. Climate Control Functions Won't Shut Down
    By helliott in forum 1991 - 1999 (E36)
    Last Post: 12-16-2004, 07:46 AM
