Results 1 to 8 of 8
Thread: Intake Boot (s52 w/ ASC)
    Oct 2015
    Alabama
    97 BMW M3 Sedan
    Good morning,
    My intake boot is dry rotted and beginning to show some crack. I was wondering if i would be able to use a Silicone 45 or 30 degree angle one and then add a port for the PCV.
    Have anyone done this? i know there's name brand ones out there already but they are like over $80 bucks..
    Current
    -1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
    Past
    -2001 BMW 325i
    -1999 BMW M3 Vert White
    -1981 VW Rabbit Pickup (Caddy) 2.0 ABA
    "I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    https://www.amazon.com/GooDeal-Flow-...e+boot+with+ac $14 and could be at your house tomorrow.
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Quote Originally Posted by BMWManiac View Post
    Really? "Goo" deal brand. How goo do you think that is?
    Don't be cheap or ghetto. Just buy OEM parts and save money in the long run. These last 10 years or more. Uro and other knock off brands are flimsy junk.
    ASC: https://www.getbmwparts.com/oem-part...se-13541740073
    ASC Delete: https://www.getbmwparts.com/oem-part...se-13541703588
    Feb 2002
    Orlando, FL
    Quote Originally Posted by Braymond141 View Post
    I bought one for my parents e36 328 and installed it today. I'll let you know if it is junk when I go to replace it again.....the guy was about to put RTV in between all the ribs....geez, no reason to pay $80 for an OEM part that isn't "critical" like a sensor.....
    Oct 2015
    Alabama
    97 BMW M3 Sedan
    Well i was asking cause some people say that smoother silicone hose helps...
    I was looking at these hoses but they have 30 http://www.siliconeintakes.com/30-silicone-elbow/ and 45 degrees http://www.siliconeintakes.com/turbocharger-part/
    Current
    Past
    -2001 BMW 325i
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by Lukitas View Post
    If you're going to eek out every fractional horsepower with smoother intake tubes, delete your ASC.
    http://www.bimmerworld.com/Intake-Fu...Air-Meter.html
    Buy OEM parts or buy high quality performance variants like what Bimmerworld sell. Stock boots are ribbed to strengthen the tube from collapsing under load. If you get too cheap of silicone, you may run into this issue. None of what you linked will work as a significant reduction in ID size is required to go from the ASC to MAF.
    AFE does make an ASC to 3.5" MAF elbow. No stock MAF boots though.
    http://www.bimmerworld.com/54-12399-...ins-ASC-T.html
    May 2018
    Anchorage Alaska
    1997 M3 Sedan
    Kinda on this topic anyone know of anyone making an elbow to retain you asc and have a hole for air temp sensor?
    Aug 2013
    1999 BMW M3 Coupe
    No I don't, and I did look a while back.
    I assume you're asking in regards to relocating the IAT sensor from an M50 manifold swap. The simpler non-destructive first option is probably to put some extra threads and RTV on the IAT sensor and screw it into the OBD1 sensor port on the M50 manifold. You could also try to cut a small hole into one of the silicone intake boots and plug the sensor in there with some sealant or epoxy, but you could very easily end up with a leak or a junked $100 intake boot. The boot is probably the better place to put the sensor if you can make it work cleanly.
    It looks like bimmerworld also sells a modified OBD2 sensor ready and threaded to plug and play into an M50 manifold if you don't want to DIY it:
    http://www.bimmerworld.com/Intake-Fu...version_2.html
  1. E36 OEM Intake Boot w/o ASC+T
    By DakarMthr33 in forum Engines, Performance Parts & Software
    Last Post: 01-06-2010, 03:06 PM
  2. Need intake boot with ASC for 98 m3
    By ToxaRu in forum BMW Parts Wanted
    Last Post: 04-08-2005, 10:16 AM
  3. FS: MZ3 Intake Boot aka ASC+t delete boot
    By Bill in forum BMW Parts For Sale
    Last Post: 10-13-2004, 07:31 AM
  4. FS: Non-ASC Intake Boot
    By NY98M3 in forum BMW Parts For Sale
    Last Post: 10-12-2004, 03:36 PM
  5. FS: Non-ASC Intake Boot
    By magnetic1 in forum BMW Parts For Sale
    Last Post: 09-26-2004, 08:01 PM
