Results 1 to 11 of 11
Thread: Nissens radiator, which one?
    UAE
    Merc R129, E31, Jag XKR
    Hi Guys
    The driver's side plastic end on my rad called it quits yesterday. Iv done my research and the Zionsville rad is out of the budget so its mostly down to Behr and Nissens however there seems to be some confusion regarding thickness and built-in or external tranny coolers. Iv got a 95 Auto (CC41312) so iv got a external tranny cooler
    #1 60747A (650 x 439 x 40 mm) (Manual)
    https://catalogue.nissens.com/Product
    #2 60748A (650 x 439 x 40 mm) (Automatic)
    #3 60622A
    650 x 438 x 32 mm
    As you can see, the only difference between them is the thickness however none of the nissens list my rad part number 17111702762 as the cross reference.
    Any help would be appreciated
    "Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Don’t buy a Nissens they’re garbage. I’ve had 2 and my fan shroud never lines up properly on them
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    If you plan on keeping the car,save up and get the Zionsville. I replaced mine with a Behr and I wished I new about the Zionsville at the time I replaced mine. It's pretty stupid to build a radiator with plastic tanks. It can't be repaired. When this one fails I will be getting the Zionsville.
    Sunny Cali,
    6.5 second 69 Camaro
    +1
    Zionsville is the best and can handle 4 times the pressure, Must have if you replace, No plastic parts!
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Seems like a waste considering the OE tanks last like 10+ years and you could buy 3 of them for the price of a Zionesville. Especially when CSFs are even nicer.
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Auxiliary water pump and heater matrix still present a weak link. I would spend the money on those first.
    Quote Originally Posted by 8eights View Post
    +1
    What "thumbs up" really means
    Sunny Cali,
    ...fwiw, My whole cooling system on both cars have been sourced far ago, The cooler you keep the flow off the back will preserve those weak plastic parts! I use a much better water pump than oem as well! Spending on the radiator either Zionsville or Mishimoto will ad longevity to your engine and trans, This drive train should never be over heated, If it cost twice as it costs now, I would still do it, You should see what it cost for the E46 guys, Three hundred more than what it cost a few years ago but it looks better, Works better and those without it shouldn't knock it without knowing how important a cooling system is on this car, I live in the desert and actually drive my cars and feel much better knowing my cooling system is repairable rather than just be replaced.
    Iceland
    BMW 850
    What kind of water pump are you running?
    UAE
    Quote Originally Posted by killian665 View Post
    Really? I searched here and the reviews are either Behr or Nissens unless you spend the big bucks
    Quote Originally Posted by toomanyparts View Post
    Deleted the heater already...it reached 50C (121F) last week and still climbing
    Correct me if im wrong but Mishimoto doesn't make rads for our cars
    Quote Originally Posted by Fatandre View Post
    Bone stock (is there an upgrade im not aware of?), but iv been a V12 E38 owner for the past 7 years and never overheated
    picked up the car a couple of months ago and brought her back to life. She was abandoned since 09
    Mar 2016
    Tyler, TX
    1992 E31 850i
    Wow, you've got your work cut out for you with that kind of rust! Definitely keep us updated on your restoration progress.
    Cheers, John
    UAE
    Quote Originally Posted by dukegrad98 View Post
    Cheers, John
    Already done and registered and driven daily-ish
  1. Behr or Nissens radiator?
    By Def in forum 1992 - 1999 M3 (E36)
    Last Post: 02-05-2010, 06:39 PM
  2. why you should never get Nissen radiators
    By Dan in forum 1996 - 2003 (E39)
    Last Post: 05-20-2007, 12:14 PM
  3. Nissens radiator.....
    By dagoo98 in forum 1996 - 2003 (E39)
    Last Post: 03-14-2007, 06:39 PM
  4. Behr or Nissen radiator
    By idreamt... in forum 1991 - 1999 (E36)
    Last Post: 10-19-2006, 12:22 PM
  5. Looking for a Nissen Radiator
    By Voyd in forum 1992 - 1999 M3 (E36)
    Last Post: 02-16-2006, 01:02 PM
