Results 1 to 5 of 5
Thread: Front latch cover clips?
    Atlanta, GA
    E36 M3 vert/E32 750/Alfa
    Hey, has anyone found a work-around if the two white plastic clips break, that hold the front latch cover (part #54 34 8 206 397) in place?
    Apparently the clips are not sold separate from the cover -- from BMW, anyway -- and the entire cover lists for, like, >$400.00 from BMW so if anyone knows a shade-tree solution or hack to get around this thank you in advance.
    Hopefully this makes sense without pics, although also hopefully not too many other people have had this issue (FWIW unfortunately BfC doesn't seem to be allowing any new images to be uploaded or any previously uploaded images to be deleted from this account right now :P )
    Cheers,
    Tazio
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    First to make sure we're talking about the same part. These are the white nylon plastic parts that are attached the cover and then attach to the top via roll pins.
    In my case, one came apart from the cover but did not actually break. The problem in reattaching them is that almost no glue will stick to the nylon plastic. What I did is to use JB Weld PlasticWeld epoxy putty to reattach it. I only assumed the putty would actually stick to the cover plastic and formed it over the clip so it wouldn't pull out. Now if your clips are actually broken, best bet is to get a good used cover or a crappy one and just transfer the clips. Whatever you do, it will be with used parts.
    "Howdy, Folks!"
    Mar 2008
    Bangkok, Thailand
    E85 Z4
    I reattached mine with epoxy resin - it was ok the first few times the roof went up and down....
    I actually sold the car about 1 year ago, and as the buyer was trying the roof (after we'd settled on money and exchanged titles) the clip came off one side, somehow put stress on the other side and the whole front cover part dropped out of position.
    Embarrassing!
    But yeah, the nylon doesn't really glue into place well - it seems they're both glued and melted into position from factory?
    Baton Rouge, LA
    '98 328i convertible
    I drilled holes and put a screw in each side. Not beautiful, but not hideous, and it works great.
    - Ken -
    Dec 2010
    Jackson NJ
    1997 328i c M trim
    I remember bullying these from pelican a few years ago for my 99 .
    Sent from my SM-N950U using Tapatalk
    This car is AWESOME !!!
  1. Replies: 6
    Last Post: 03-26-2012, 06:07 PM
  2. FS ACS Front Bumper Cover
    By BAADDOG in forum BMW Parts For Sale
    Last Post: 04-27-2002, 07:38 AM
  3. Replies: 0
    Last Post: 03-15-2002, 01:04 PM
  4. Removing front bumper cover
    By 98M3_4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-27-2002, 07:02 AM
  5. Front End Cover - Feedback
    By hotbimmer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-16-2001, 11:52 PM
