Results 1 to 3 of 3
Thread: Vacuum leak oil stick ?!
    Sep 2016
    Belgrade
    Is it possible that a oilstick two seals/O-ring when in bad condidion, can make vacuum leak on E30 ? It is number 15 on photo :
    http://bmwfans.info/parts-catalog/E3..._pan_dipstick/
    Also , I want to have one good MAF in reserve. I got good deal for MAF from E36 318i M43. Whether it can be used for my E30 318i M40 without any problems ?
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    If the dipstick doesn’t seal well it will cause a vacuum leak indeed.
    No idea about the M43 parts compatibilty with the M40.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Sep 2016
    Belgrade
    Quote Originally Posted by 323i E30 View Post
    Ok, thanks!
    Also, I put EVAP valve and ICV valve from E36 m43 on E30 m40 and everything is ok. In EPC MAF number 13 62 7 547 980 from E36 m43 is compatible with E30 318i M40. So, did any try that "combination" in practise...
    http://bmwfans.info/parts-catalog/13627547980/
  1. Coolant, vacuum, and oil leak questions
    By BavMoWo in forum 1983 - 1991 (E30)
    Last Post: 03-19-2013, 01:32 PM
  2. 2000 E39 528i...Oil leaks, vacuum leaks, codes..ohh my!
    By justinsane187 in forum 1996 - 2003 (E39)
    Last Post: 07-10-2012, 08:46 AM
  3. Oil Leaks, Vacuum Leaks, ETC!
    By V8Wagon in forum 1988 - 1996 (E34)
    Last Post: 05-17-2012, 12:12 PM
  4. '06 750LI: Vacuum Pump leaking oil
    By oz333 in forum 2002 - 2008 (E65, E66)
    Last Post: 12-23-2011, 03:41 PM
  5. Replies: 17
    Last Post: 12-23-2009, 01:04 AM
