Results 1 to 25 of 37
Thread: 17x8 Style 5s on e36 help
    Oct 2017
    Orangeburg, SC
    1999 BMW M3 Convertible
    Just want to say sorry beforehand but I can’t seem to get definite answers even though there are so many posts on the subject
    I just picked up a set of 5 Style 5s for 200 bucks & will be putting them on my e36m. I know I need rings but what about 5mm spacers? Do they clear the M brakes without them?
    Also I will not be rolling my fenders & the car is lowered. Would 215s or 205s make it happen?
    A little bit of rubbing isn’t a problem for me.
    Oct 2017
    Orangeburg, SC
    Any help?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 forum
    Jul 2015
    Clarkston Wa/Lewiston ID
    96 328i coupe
    205/40/17 will help get everything to fit, no idea on the spacers but plan on doing lots of rear fender work, there is a ton of metal that is back there and just about as in the way as possible. Some good stiff coilovers will help as well
    Oct 2017
    Orangeburg, SC
    Should I throw my stock springs back on in the rear or would you have any recommendations?
    Jul 2015
    96 328i coupe
    I always recommend high rate coilovers from Broadway Static, stock springs are tall but very soft
    The Netherlands
    DE-spec E36 328i/M3 cab
    The ET value will be the main factor.
    There are different versions of the 8x17” version.
    If they have (around) ET41 you will have no issue and can fit a normal sized tire.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Jul 2015
    96 328i coupe
    Most 17x8 that I have seen are +20, same size and offset that I ran for quite a while, if you have the +41 offset you will be fine
    Oct 2017
    Orangeburg, SC
    Appreciate the help
    Mine are the +20
    Jul 2015
    96 328i coupe
    yeah +20 take a fair amount of fender rolling and pulling but fill out the stock body really well
    Oct 2017
    Orangeburg, SC
    Not looking forward to touching the fenders
    Jul 2015
    96 328i coupe
    Quote Originally Posted by e36Jam View Post
    Just use a heat gun and go slow with the fender roller, should leave the outside of the body looking stock
    The Netherlands
    If no fender work, it’ll be silly camber.
    IG:
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    ET20 wheels on the E36 will be located closer to the fender, leaving less room for the tire. The Style 5 are nice BBS 2 piece wheels but the E39 version in 17x8 ET20 does not fit the E36 well for performance use because you must use narrow tires. Even with excessive rear camber like kids think looks cool, you can’t really fit even stock M3 size rear tires and the silly camber wears out tires and makes handling worse. If you are happy with 205s maybe 215s then you will be ok. An Eastwood type fender roller is about $70 these days.
    The Netherlands
    You may get away with it...just.
    8x17 ET20 vs 8.5x17 ET41 for the widest stock (M3) wheel.
    Since ET is the distance to the centerline of the width, changing the width also affects the ET (with all other things being equal)
    So in this case if you would go from an M3 wheel, to above 8" wide Et 20 wheel, the wheel will come 15mm more outwards.
    There is quite some room even with stock M3 wheels, so rubbing might only be a bit / an inner lip role maybe all that is needed.
    And then you can run normal width tires.
    IG:
    Oct 2017
    Orangeburg, SC
    Looking for a local shop that can do a decent roll before I try my hand at it. hopefully I can keep near stock body lines
    The Netherlands
    If you roll the inner lip flat against the outside frees quite some room and will be invisible from the outside.
    IG:
    Oct 2017
    Orangeburg, SC
    That’s good to hear. Eases some worries. I definitely want to avoid waves/bumps or paint chips.
    Jun 2005
    New England
    Dig out the goo before rolling the inner lip. It’s not easy to dig out. But you can then roll the inner lip flatter.
    Oct 2017
    Orangeburg, SC
    Found one place local in Columbia that quoted 100 for just the rears. Is it necessary to get the fronts done too? Trying to get 225s to fit all around after the roll.
    Jul 2015
    96 328i coupe
    Depends, test fit them and post up pics, $50/fender is at the high end of what I would pay and I would expect the results to be pretty much perfect
    Oct 2017
    Orangeburg, SC
    Also maxed out my coils today & picked up some of the 10-15mm oem pads from the junkyard to give the rear as much clearance as possible
    Jun 2005
    New England
    Is it really worthwhile to run these wheels given the figment issues and need to limit tire width and/or raise ride height? They are a downgrade from 17” M3 staggered wheels for performance. An upgrade from 15s. Probably an upgrade from 16s.
    Oct 2017
    Orangeburg, SC
    My e36 M is a convertible w an auto trans. I am not particularly concerned with performance. Just looks & a reasonable amount of functionality as my daily driver. Fenders will be rolled Tuesday afternoon. I’ll take some before & after pictures
    Jun 2005
    New England
    They are good looking wheels. I put a set on my 99 528i. I took them apart, stripped them, polished and powder coated in clear coat. Much bigger job than I thought it would be.
  1. WTT: E39 style 5s for E36 M3 help.
    By Wishno87 in forum Pacific Northwest - US
    Last Post: 09-10-2012, 02:28 AM
  2. E36 17x8 Style 5s w/Tires
    By DannyE30 in forum Wheels and Tires
    Last Post: 12-09-2011, 05:48 AM
  3. 17x8 Style 5s on an E36 M3
    By BimmerDude3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-19-2011, 04:02 PM
  4. style 5s on e36? et41 vs et20? Help!!!
    By pro325 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-23-2010, 03:19 PM
  5. looking into style 5s for e36
    By sxcsupra in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-06-2007, 11:57 AM
