Results 1 to 14 of 14
Thread: New OEM jack pads don’t fit
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Im getting really sick of these cars because it seems everything I do ends with an ordeal like this.
    I waited 2 weeks for two brand new OEM front jack pads. They don’t fit for fuck. It’s as if the plastic casting is off and they bottom out on the rocker before the tabs can seat and snap in the hole. Has anyone run in to this before is this a known issue?
    Las Vegas, NV
    1994 850CSi, 2007 M5
    Are you referring to #18 in the below link? If so, I recently replaced both front and rear OEM jack pads with no issue.
    https://www.realoem.com/bmw/enUS/sho...diagId=41_0887
    1994 850CSi, 2007 M5, 1990 VW Westy Syncro, 2010 e61 Touring Manual
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Yes number 18. I pop them in and they don’t stay snapped in tightly. I can pop them out with my pinky.
    My observation is that the fin parts of the plastic are too long and they bottom out on the body of the car before the tabs can seat and hold the block in. It’s either that or the tabs are faulty and won’t lock in properly but I’m leaning more towards the former after I tried putting in.
    Mar 2008
    montreal,Canada
    bmw 850
    there might be an issue with some jack pads because i lost a front one days after i put it on,
    at the time i thought maybe i hadnt put it on firmly enough.
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by razman850 View Post
    I've lost a few over the years. One of the "experts" here recommended doing a proper cleaning of the area then apply a bit of adhesive to the pad area that makes contact with the frame. So far I have seen another pad tumbling down the freeway in the rearview mirror.
    1993 850Ci.....18 years & 165,000 miles and counting!
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    Just use butyl rope and cut a piece and put it around the opening. It will stay put and can be removed later without issue.
    What "thumbs up" really means
    Apr 2018
    Essex, UK
    '95 840Ci, '06 730d
    I feel your pain, I had this too when I bought a full set of pads. They just didn’t seem to clip into the aperture properly. Haven’t found a solution to hold them more securely but haven’t lost any so far. Would grinding down the top surface of the tall extrusion help do you think?
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That was my thinking and I was going try it however if that ends up not being the problem and it’s the actual clips themselves not being tight enough or whatever then I can’t return it. That’s $50 I could use getting some different ones to try.
    We had an 850 in the shop a while back that we bought some for and they worked fine so it looks like it’s a real hit or miss with these things.
    Toronto, Canada
    BMW 850CSi
    I forget, but do these only go in one way? Try re-orienting 180 degrees? Otherwise, it has been suggested to silicone them in.
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    When I have put new pads on the 8's I have redone, I do what was mentioned way back in Roadfly days. Take some black silicone, put around the tabs that fit up into the holes, put them into place and let the silicone cure. Mine have never come off after doing this, but you can still remove them if needed.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Oct 2016
    Brisbane, Australia
    1994 840ci
    If you use silicone to hold stuff on, make sure it is not acidic. Before I saw the light and got an 8, I had a W126 Mercedes SEC with AMG side skirts. When I went to remove them, the rusty sides of the sills came with them! The acid in the silicone had caused the metal to rust out, leaving me with 4 foot long strips as wide as my finger with no steel left...
    Mar 2011
    Good call. Just use butyl.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    I’d rather not rig it to fit I kinda just want one that fits as designed.
    Apr 2008
    UK
    BMW 850CSi, E53 X5 4.8iS
    Quote Originally Posted by rogbmw View Post
    This is the way to do it and if the car has been lifted without the pads in place, the jacking points will be out of shape.
  1. E9x Three (3) New - OE Jack Pads
    By Jmanscotch in forum 3 series & Z Series
    Last Post: 04-11-2012, 09:44 PM
  2. E46 FS: E46 Front License Plate holder A/W and new OEM First Aid Kit fits under seats
    By AWIRM3 in forum Exterior Lighting & Body Parts
    Last Post: 04-28-2011, 10:05 PM
  3. OEM jack pads
    By stengesd in forum 8 Series (E31)
    Last Post: 04-11-2010, 12:03 PM
  4. FS NEW E36 jack pad - Chicago IL
    By Joeytse in forum Suspensions, Springs & Shocks
    Last Post: 07-20-2008, 03:30 PM
  5. brake pads dont fit
    By E30Driftin in forum 1983 - 1991 (E30)
    Last Post: 06-01-2007, 07:57 PM
