Results 1 to 7 of 7
Thread: Turbo e34 540 i
    Aug 2018
    USA
    1995 BMW e34 540 i
    Turbo e34 540 i
    I am planning on purchasing a 1995 540 i and turbocharging it. What do I need to get started and what is the most reasonable turbo I could put in it for a starter ?
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    E34 is very tricky to put front mounted intercooler. I had to lose the Ac condenser as with it in place you have to almost have the cores touch each other. The m60 very underrated engine. Saw on latest performance bmw magazine that some chap is managing some big power 700rwhp or something out of internally standard engine. I’ve got a supercharged m60 running 14psi and it’s begging for more timing & drivability is very good. I’ve got a larger crank pulley that will prob push over 16psi drawn up ready to lite the fuse on.
    Good luck. See the dudmd thread on here.
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
    Aug 2009
    Charleston, SC
    x5m
    Your best option is to get a 6 cylinder call and turbo that instead. Having turbo'd a 540, I can promise you that would be the easier option. That said, if you choose to go down the 540 route, you will need custom manifolds. Don't expect anything off the shelf - there is none. Like Gaz said, intercooler is tricky. You'll likely loose either AC or the front bumper. You'll probably want to go the standalone route. Turbo size is completely up to you. Big top end or useable throughout?
    Here's my semi-build thread to give you some ideas.
    https://www.bimmerforums.com/forum/s...squirt-content
    e70 x5m vrsf downpipes and turbolabs turbos - current
    e34 540 turbo take 2 - sold
    e34 540 turbo - crashed and burned
    Dec 2005
    E24, E34 x2, E36
    Yes 6cyl much easier to turbo especial in a e34 chassis. The e34 is probably the worst bmw to run an air/air intercooler on. In e28 there is a massive space for one. The e34 chassis copes with big power nicely tho.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
    Dec 2014
    Marin,Ca.
    4.9L 540i/Porsche 997
    I have a RMS after cooler, and it works pretty good. It is the only thing that works from RMS, I was warned but I am stubborn. That said, aftercoolers work for my 540i. I am in the process right now to replace my Vortech V2 Ti based s/c system with a turbo kit custom made by Zack at 222RPD. I have always respected the options tubos offer, mainly adjustability of boost on the fly and no parasitic loss. What I have personally learned is one is not "better" than the other, but rather that either one can hopefully satisfy different goals. There is more than 1 way to skin a skunk (I would never skin a cat ). I will start a new thread with Zack in the near future. As of today I am looking at several transportation companys to get my 540i from Bay Area to Seattle area asap (lowest quote so far is $1045). Any suggestions? Also Hps9 I am going with a Precision single turbo and I already have a fully built 4.9L M62 to use. Good luck and wish you the best in your adventure. Zack is a great guy to talk to and very knowledgeable. He also is a member here as "vollosso".
    22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
    Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
    Apr 2008
    colorado springs
    1993 740i build 11/92
    Anything come from this project? Any new developments from anyone?
    Dec 2014
    Marin,Ca.
    Quote Originally Posted by Steeltag View Post
    Sorry I don't know anything about this build, but I am also doing a E34 540i/6 turbo project FYI. Hope my build helps.
  1. I made an turbo - e34 540 and megasquirt content
    By motorokr718 in forum Forced Induction
    Last Post: 06-09-2018, 08:20 PM
  2. E34 WTB large case E32/e34 540 output flange please please!!
    By mattymic in forum BMW Parts Wanted
    Last Post: 09-03-2011, 11:08 PM
  3. E34 F/S for now. E34 540/6, sc'd, track car
    By E34nication in forum 5 series & 6 series
    Last Post: 10-13-2010, 09:15 PM
  4. E34 540 Supercharge or turbo
    By mean green 540 in forum Forced Induction
    Last Post: 07-22-2009, 07:44 AM
  5. thinking of turboing my e34 540/6 any ideas??
    By e34bmw540i in forum Forced Induction
    Last Post: 10-14-2007, 07:09 PM
