Results 1 to 2 of 2
Thread: E60 fault codes and airbag light on!
    Nov 2016
    Iceland
    Bmw 545 2004
    Í Have This airbag light on which says front passenger seat airbag fault. Pulled the codes and they are:
    93a8, ce99, 613f, 6140, 6145. What do all these codes mean? Are they all about this airbag light? What would you guys try to change to repair this? Clock spring or some airbag wiring bypass under the seat or what? Can you tell me what those codes mean? Thanks
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    have you tried clearing the codes, has seat been removed for any reason? Some e60's had a connector under rear of pass seat that a back seat rider might kick with his/her feet and cause it to disconnect.
    Level 1 Certified BMW tech.
  1. 1996 328i Fault Codes / Check Engine Light
    By jball-328i in forum 1991 - 1999 (E36)
    Last Post: 06-08-2018, 01:05 PM
  2. P1620 fault code/ service engine light
    By crichmac in forum 1999 - 2006 (E46)
    Last Post: 03-22-2015, 08:10 PM
  3. e92 dme sensors fault codes engine management light
    By dellboykev in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-26-2013, 06:10 PM
  4. Misfire but no fault code or engine light
    By grumpy27 in forum 1999 - 2006 (E46)
    Last Post: 08-04-2013, 05:02 PM
  5. Replies: 1
    Last Post: 10-30-2011, 03:00 PM
