Results 1 to 3 of 3
    Atlanta, GA
    99 M3
    What else to change when replacing the A/C compressor?
    Hi all!
    I've done some light A/C work in the past, but never had to open the line. Just inherited a nice E53 X5, but it came with a broken AC. It looks to me like the compressor since the low and high side measurements are the same, whether the compressor is engaged or not. Pipes are warm or hot to the touch whether filled to 25 PSI (presumed closed) or higher. Yes I can see the clutch engaging so i've ruled out an electrical problem.
    I recall that whenever you have to open the line, you also need to replace the receiver/dryer. Is there anything else that is mandatory to replace, or is just a good call, to do when you do the compressor? Seals, etc?
    Oct 2003
    Seattle
    99 M3
    Pressure valve, dryer and relate seals
    Feb 2010
    Louisville, KY
    1995 BMW 525i
    I'd replace the o-rings too. Make sure you get the ones ok for hvac use.
  1. Replies: 4
    Last Post: 09-27-2007, 05:49 PM
  2. what else to change while doing clutch/
    By CosmoE36 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-13-2006, 09:39 PM
  3. What else should I change while replacing the clutch?
    By Andryuha in forum 1996 - 2003 (E39)
    Last Post: 06-19-2006, 10:38 AM
  4. 96+ control arms on a '95. What else to change besides bushings?
    By fritzintn in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2005, 09:28 PM
  5. What else to change with voltage regulator??
    By peakay in forum 1992 - 1999 M3 (E36)
    Last Post: 08-26-2004, 03:21 PM
