Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Back in the game!
  1. #26
    Jan 2015
    Belgium
    e32 730i
    Quote Originally Posted by youngbimmer View Post
    8. Headliner is ratty.....really ratty. I don't think I'm brave enough to tackle this myself, but maybe I'll recruit a friend to help.
    Not that long ago I replaced my headliner. It's actually a lot easier than I thought, it just consumes a lot of time. It can be done alone, but you will need a second person to get it out of the car (this is actually the hardest part, along with reattaching it at the rear end side)
  2. #27
    Richmond, Virginia
    '88 735i, '06 RSX
    Appreciate all the input guys. Seeing as how this car is 30 years old, I think it's time to refresh many of the major parts. The list so far:
    BMW Water Pump - Hepu 11519070761
    BMW Water Pump Gasket - Victor Reinz 11511265654
    BMW Fan Clutch - Behr 11527831619
    BMW Fan Blade (E36 E46) - coolXpert 11521712058
    BMW Radiator - Nissens 60597A
    BMW Radiator Hose Lower - OEM Rein 11531713221
    BMW Radiator Hose Upper - Rein 11531722682
    BMW Coolant Hose - Febi 11531266459
    BMW Black Vacuum Hose (1 Meter) - CRP 11727545323
    BMW Distributor Rotor - Bremi (OEM) 12111734110
    BMW Distributor Cap - Bremi (OEM) 12111725070
    BMW WR8LC+ Spark Plug - Bosch 7909 x 6
    BMW Auto Trans Mount - Febi 24711131663 x 2
    Instrument Panel Light Bulb - Osram 2721MF x 16 (i'm going to do this once for every bulb and be done with it)
    BMW Instrument Bulb - Genuine BMW 07119905358 x 3
    Instrument Panel Light Bulb - Osram 39118 x 6
    BMW Hood Support Strut (735 740 750) - Stabilus 51231908465 x 2
    BMW Chain Tensioner - Genuine BMW 32421707199 (because knowing my luck I am going to be stripping this...)
    BMW Chain Tensioner - Genuine BMW 64551714458 (same deal here)
    BMW Accessory Drive Belt Fan and Alternator - Genuine BMW 11231711090
    BMW Accessory Drive Belt Power Steering (524td 535i 735i 735iL M3) - Genuine BMW 11231709638
    BMW A/C Drive Belt (735i 535i) - Contitech 13X855
    BMW Alternator Idler Nut - Genuine BMW 12317677914 (again, will probably destroy this)
    BMW Brake Fluid Pressure Sensor - ATE 34331150922 (leaking already)
    BMW Brake Pressure Switch - ATE 34351182270 (leaking already)
    BMW Brake Pressure Accumulator - ATE 34331162054
    Grand total thus far is $735 (what are the odds, right?)
    Looking for additional input as to what would be good to replace on a 30 year old BMW, as well as the part numbers for those ever so important 2 plastic nuts for the diagnostic plug that prevents it from rubbing on the body, destroying the protective sheathing and setting the whole car ablaze with a nice short...thanks fellas!
  1. wooHOOO back in the game!!
    By 95MMM in forum 1992 - 1999 M3 (E36)
    Last Post: 06-17-2004, 03:51 AM
  2. Back in the game!!!!! Suggestions?
    By shanepx2 in forum BMW Rides & Events
    Last Post: 06-10-2004, 08:55 PM
  3. Back From the Game
    By SR20Fastback in forum Off-Topic
    Last Post: 09-14-2003, 09:30 PM
  4. comin back into the game
    By Dj Waffelz in forum Off-Topic
    Last Post: 09-01-2003, 01:13 PM
