Ok so one of my e21s failed smog today - first time this has happened.
Test results see it is running way to rich : yet plugs read that mixture is spot on, they are light gray everywhere.
And the fuel mixture adjustment is .78v to .81v at the O2 sensor.
Bad reading are at 2,200 rpm
Timing is 25 at 2,400 rpm
15mph CO2 10.1 O2 2.4 HC 2257 CO 4.75 NO 478
25mph 12.3 O2 2.5 HC 2711 CO .77 NO 766
Also the fuel distributor adjust is really touchy it jumps from 1.9 to 7.9 with a little adjustment no way to adjust between these two adjustments.
Any ideas needed - thanks!
Bump because I go to deq on Thursday... Lol.
Sent from my SM-G955U using Tapatalk
That HC is way up there. HC is 'raw' fuel, ie: weak sparks, vacuum leak or poor compression. Maybe wrong spark plug gaps or using fancy plugs instead of plain copper or silver plugs. Check the valve clearances too : .008" for high miles engine.
CO is the black exhaust soot.
The jumpy fuel mix may be from the meter plate not being level, ie: resting low.
Tbd
Move to TX
Could one of the injectors be leaking ? worst case induce a small vacuum leak to lean out the afr
This is the next test - check injectors.
Checked for vacuum leaks = none
Checked timing = good
ignition is good
o2 sensor seems good as I can adjust it to .79 to .8 volts - but it jumps around not a steady reading.
And again all four plugs were a dry light gray color which to me shows a slight lean condition? I am thinking a leaking injector would cause a darker wet plug?
Another thought related to the high HCs.. maybe the centrifugal advance is advancing the timing more than it's suppose to, at lower rpms, ie: broken or stretched spring?
Check this, very informative.
https://www.smogtips.com/failed-high...carbons-HC.cfm
Tbd
The easiest and cheapest is a new 02 sensor. Then CAT converter. How old is the CAT converter? Check pre CAT CO/HC and compare with post CAT and see if CAT is doing anything..
02 sensor voltage will oscillate since frequency valve is at 50% cycle that affects mixture.
With known good 02 sensor try disconnecting the 02 sensor and see if it runs richer or leaner, it will tell you how to adjust the mix baseline.
Max
Thank you all for your help!
Will let you know how it does in the retest.
And I failed HC Testing as well, any help is appreciated. I think I'm going to follow some of the advice already given - however, if anyone thinks the above doesn't apply please feel free to chime in.
HC STD CO STD CO_CO2 HC CO CO2 RPM Readings: Idle Results: 220 1 6 425 0.6643 12.3 NA 2nd Idle 220 1 6 544 0.746 12.1 NA
Probably weak sparks. use only plain copper or silver plugs, gapped no bigger than .028" for the points ignition. If you still got the OE ballast wire, it's past due for replacement/retrofit. Also make sure that battery voltage is above 12.5 volts at idle speed. As mentioned earlier, make sure no vacuum leaks too!
Remember that HC is 'raw' fuel coming out the tail pipe and CO is black soot out the tail pipe.
Here's the link about HC again
Tbd
Past, Present, and Future
1974 BMW 2002tii (RIP)
1995 BMW 325is w/ FULL S50 swap, track prepped (SOLD)
1988 BMW 325ix Zinno/Black (RIP)
1988 BMW 325ix Alpine/Black (Sold)
1988 BMW 535is Alpine/Pacific Blue (Going Away...)
1982 BMW 323i (Current Project/Paper Weight)
2003 BMW 325i Sport Touring (Daily Driver)
Will do. I'm going to additionally replace the air filter as well as run her before I take her in. It was noted somewhere that it helps if the cat is hot before testing.
I was thinking it was terrible, however, I had to remind myself that we are talking about ppm.
Thanks for the advice. I also read that article earlier, thanks for the reference. I'll let you guys know when I give her a second run.
The '77-'79 (2.0) does not have a 'cat / O2 sensor', it has a unique exhaust manifold (reactor), air injection and egr. I just remembered the air injection plays a major role to reduce HCs at idle speeds. more on this later if all the other stuff is good.
*the reactor should be tested hot, just like a 'cat' tho.
Tbd
Higher numbers across the board may mean that the catalyst is no longer working and nothing is wrong with the adjustments, etc. They do have a limited lifespan, especially the aftermarket ones. If everything is working right and adjusted correctly I would start by replacing the 02 sensor which is cheap for our cars ($30). After the 02 sensor replacement mixture adjustments may need to be done. If that does not solve the problem then check the CO before and after catalyst and see if the catalyst itself is actually working.
Eve though there is no emissions testing for my car here in VT, I recently replaced my old beat up catalyst with the DEC replacement and was very satisfied with the fitment and performance. I believe it is a Magnaflow unit that comes with the downpipes and is a bolt on. It seems to have larger pipes and a high flow catalyst when compared to stock. Not cheap, especially for CA folks, but worked for me.
Max
Catalytic converters get dated as CARB changes the standards, thus a new Catalytic Converter you'll pass.
Randy
