Results 1 to 11 of 11
Thread: front light strip resistors?
    Feb 2012
    Southern Ontario
    93 850Ci, 2012 X5 35d
    I'm going over my front light strips, that have the daytime running light, the signal light and the corner light... there appears to be some melting going on, there are two white boxes in the wiring harness, are they resistors? what do the do? the housings are cracked, I'm epoxying them, and the wiring is brittle and some insulation is stripped, i'd like to replace things, but don't know what to do about the hot white boxes.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    From the inside edge you have - FTP flashers (used as main beams in the Euro versions), sidelights (in Canada this bulb is also used for DLR's - the bulb is a two-element type, one for sidelights, one for DRL) - and finally, at the outside edge are the indicators:
    As you have a couple of boxes I guess that someone has fitted LED's that require external regulators. More info here:
    https://www.meeknet.co.uk/E31/E31_FTP_Improvements.htm
    https://www.meeknet.co.uk/E31/BMW_E3...in_the_FTP.htm
    My BMW Repair YouTube Channel
    Feb 2012
    Southern Ontario
    I've never replaced any of the bulbs, so haven't checked the bulbs...I do run smoke coloured covers over the lenses, so I'm losing any performance gains of the LEDS...
    All I'm worried about is the heat from the resistors, i'll reinsulate the bare wires etc, and go from there...
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Replace the FTP harnesses. Get rid of any LED's. Go with the stock lights.
    Feb 2012
    Southern Ontario
    Quote Originally Posted by radlaw View Post
    Just to alleviate the heat issue? or something else? If I can find stock harnesses at a wrecker it would be easy, putting it back from what it is now, using the existing isn't easy, since I don't know what the original configuration was...I can use a wiring diagram, but the harnesses have been cut and pasted....
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    I believe new harnesses are available.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    They are - but more expensive than the light strip itself!
    Feb 2012
    Southern Ontario
    There was a resistor in the turn signal circuit, with a two element 1157 bulb. I have a rapid blink signal now, all bulbs front and rear are ok, so I think the resistor is gone. Should this have dual circuits? or just a single 7506 bulb?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It's a single element in the Euro lights (and for ROW as well AFAIK) - check all three bulbs for each side of the indicators - I bet at least one is an LED....
    Feb 2012
    Southern Ontario
    The centre light had an LED, I've cut out the resistors( they were in parallel) taped up the wires, and put normal bulbs in. See new thread about the fast blinker I have...that I had when this started, I thought is was a bad resistor...but it's not...
    Toronto, Canada
    BMW 850CSi
    The center bulb is a 2-element bulb, but not a 1157. It’s a P21/5W. They are different.
  1. Looking for a front (passenger side) Light Strip...
    By madelife08 in forum 8 Series (E31)
    Last Post: 10-08-2008, 08:32 PM
  2. Euro Front Plates Strip
    By slickav in forum 1991 - 1999 (E36)
    Last Post: 04-15-2003, 09:37 PM
  3. WTB Front Light Housing, mine busted! ARGH! (m)
    By Z3POWER in forum BMW Parts Wanted
    Last Post: 04-01-2003, 08:40 AM
  4. WTB Front Light Housing, mine busted! ARGH! (m)
    By Z3POWER in forum 1996 - 2002 Z3 (E36/7, E36/8)
  5. F.S. OEM Exhaust/front lights/complete lens set
    By BMWManiac in forum BMW Parts For Sale
    Last Post: 04-25-2002, 10:00 PM
