Results 1 to 25 of 51
Thread: Thermostat Housing Leaks After Replacing Thermostat
    San Diego, CA
    '06 530i, '16 320i
    Question Thermostat Housing Leaks After Replacing Thermostat
    I replaced my thermostat over the weekend and it wasn't too bad. But afterward, coolant came leaking out of the housing near the lower left-hand mounting bolt. I installed an original looking housing gasket but was there more I needed to do? Do I need a new housing or just use some silicone sealant? 1992 318i Build 7/92.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    I'm not familiar with the 4-bangers, but assuming they're similar to the M50/M52, BMW considered the plastic housings a one-time use. That's debatable but you definitely need a new gasket and likely some RTV.
    Apr 2017
    NJ
    1995 318ic
    If you have the aluminum housing, that can be reused with a thin layer of rtv on the gasket. I went with the elring gasket (no rtv), no leaks yet. Good luck
    Apr 2014
    UK
    1995 BMW 328
    Nothing up with the 6 pot thermostat housings, mostly, if not near always, down to bad technique fitting when they crack
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    San Diego, CA
    '06 530i, '16 320i
    Quote Originally Posted by Nanniepoo View Post
    Yeah its an M42. I have the aluminum housing.
    San Diego, CA
    '06 530i, '16 320i
    Quote Originally Posted by thenjnick View Post
    I did not even see a gasket when I removed the housing. Maybe it completely deteriorated. The new housing gasket has two thin beads but probably wasn't enough. I think the mechanic I had replace the thermostat years ago used RTV.
    Apr 2017
    NJ
    1995 318ic
    Quote Originally Posted by donb318 View Post
    Mine was the same way. Only a millimeter of gasket left if even that and it took a lot of wire brushing to get the remnants off. My gasket had the pre-beaded rtv as well so i decided not to use more. Maybe the housing is warped enough to drip? I checked mine with a metal ruler and it looked alright. I also cleaned the mating surface really, really good and positioned it on super carefully. I’m convinced my OCD helped me on this one.
    Oct 2005
    San Francisco, CA, USA
    '94 318ic, '00 323it
    Use RTV on the aluminum gasket surface. Don't bother with a gasket. The aluminum housings never had a good mating surface. Also check if there is no debris on the mating surface.
    Alpine 318ic FTMFW!
    San Diego, CA
    '06 530i, '16 320i
    Come to think of it, my housing might be warped because I noticed the bolts weren't torqueing evenly. I'd get them torqued but then tightening one would make the rest need further tightening. I kept having to go around and around until they seemed to all decide to finish torqueing.
    Quote Originally Posted by myblackcar View Post
    That was going to be my next question if using RTV still requires the gasket. I guess it depends on if you use a thick bead or a thin one.
    Apr 2017
    NJ
    1995 318ic
    Thats sounds pretty normal to me. Did you use a torque wrench? I tightened them by hand but not too much, not as much as i wanted to at least haha but the housing is pretty soft so it could have bent easily..maybe just enough rtv will do the trick? I think they run ~$90 on fcp iirc
    San Diego, CA
    '06 530i, '16 320i
    I torqued to the specified 89 inch/lbs. $90 for RTV? Wha what?
    Apr 2017
    NJ
    1995 318ic
    No I meant the thermostat housing sorry. Its $53 on pelican plus shipping.
    https://www.pelicanparts.com/More_In...SVSVSI=128.htm
    I think you should be fine if you replace it and just put a new gasket with rtv to be safe, otherwise just use a generous amount of rtv on the old housing.
    San Diego, CA
    '06 530i, '16 320i
    Generous amount of RTV would be a quicker fix but a new housing would be ideal. I found an OEM housing on eBay with gasket for $55, free shipping, no tax.
    Apr 2017
    NJ
    1995 318ic
    Good deal. Let us know how it goes. I have to go top off my rad and bleed again, thing is overheating now. Hopefully im not losing coolant and some air is trapped in there. Ugh
    San Diego, CA
    '06 530i, '16 320i
    Will let you know when I get it done. I have two BMW's and so I'm not really in a hurry. Probably next weekend. When I had air in my coolant system, it would over heat right away. I actually didn't bleed it at all. But once I bled it, all was well. I have a new radiator, water pump, fan clutch, radiator cap and fan shroud though. Thermostat just recently started sticking.
    Apr 2017
    NJ
    1995 318ic
    Not sure why mine is starting to overheat all of a sudden, everything was fine since i put in a new radiator two weeks ago. My brother uses the car 5 days a week so I dont get much time to look it over. Hoping a refill and bleed will do the trick. We’ll see
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Probably just needs to be bled some more
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    San Diego, CA
    '06 530i, '16 320i
    What's it actually doing?
    I believe when there is air in the system, the temp gauge will intermittently shoot into the red. At least that's what mine did.
    Dec 2014
    Alexandria, Va
    1996 328is, 2003 325ci
    Maybe it's possible that the thermostat moved out of position before bolting the housing down tight. If so that may explain the odd bolt tightening and leak. Seems like you need to remove it and recheck.
    San Diego, CA
    '06 530i, '16 320i
    Quote Originally Posted by woody328is View Post
    I opened it back up and the thermostat was still in place, spot on. I'm just gonna replace the housing.
    Dec 2014
    Alexandria, Va
    Smart move. It was just a thought.
    Apr 2017
    NJ
    1995 318ic
    Quote Originally Posted by BMWManiac View Post
    Agreed. I topped it off and bled it yesterday, ran it for a while with no overheating. Ill check the level tomorrow.
    I honestly don’t know what happened prior to it shooting into the red, I tried to get more info but no go. I think trapped air is a good bet, however the aux fan isn’t being triggered by the temp switch or the AC plus it was a hot day so that’s most likely the cause. Could there be such a large air pocket that left me over a liter dry on coolant even after driving it a few days without issue? I did drain the block too..still seems odd to me
    Im just worried about the condition of the head gasket at this point. The car has overheated a few times now and im hoping to do a compression/leak down test soon.
    Apr 2017
    NJ
    1995 318ic
    Sorry I dont mean to threadjack...
    Aug 2018
    Fayette County
    1999 328is
    Shoulda used plastic maybe.....
    Apr 2015
    Sacramento CA
    2001 Z3 Roadster
    When I changed my t/stat housing I sanded it flat before installing. Even brand new it was a bit warped. Granted it was on a 6 cyl.
  1. Replaced M42 318i thermostat, housing leaking. Use sealant?
    By Not Sure in forum 1991 - 1999 (E36)
    Last Post: 01-17-2011, 01:57 PM
  2. Aluminum Thermostat Housing leaking after 1k miles
    By juiceman in forum 1996 - 2003 (E39)
    Last Post: 05-05-2009, 05:29 AM
  3. Coolant leak around thermostat cover after replacing thermostat
    By DSrugis in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2008, 08:02 PM
  4. Coolant leak after replacing radiator, thermostat, water pump
    By Hawkman in forum 1992 - 1999 M3 (E36)
    Last Post: 04-18-2008, 06:29 PM
  5. Coolant level-after replacing thermostat
    By ScottDetroit in forum 1992 - 1999 M3 (E36)
    Last Post: 10-04-2001, 06:31 PM
