the issue I have with acceleration: once i accelerate hard for a couple of seconds, gaining fast incremental speed, the engine light will come on and suggest that there's an engine malfunction AND that it will operate at reduced power...but I really don't see any measure of reduced power (accelerating or steady driving) - and if so, not even close to the power reduction I experienced when the crankshaft position sensor was faulty.
So, the warning light comes on but I don't see any difference in the actual power in the vehicle itself - I can continue to higher speeds and accelerate.
I'm curious to know is that a faulty wire or sensor somewhere, obviously something is going on but it's connected to the accelerated pedal and gradual but fast incremental speed...and it can happen from any particular initialization - from 0-miles per hour or from 40-miles per hour.
I can clear the engine warning light and malfunction message by restarting the vehicle and it won't reappear until I do a hard acceleration again which I normally don't - really only to test.
I can say that it happens in regular drive, in sport drive, but not in manual drive...and when it does happen no codes are shown or stored only the malfunction message and engine light which can be cleared by turning the vehicle off then back on again.
It occurs on the down slide from 3500 RPMs and pops on at about 3000 RPMs.
Pull the codes, fix the problem.
Are you gonna eat that?
check all your vacuum hoses for the wastegate controllers. Including the 2 that run down past the oil filter. They love to crumble and any leaks will cause symptoms like you describe. It will store codes for boost control if this is the issue(i dont remember the exact codes or wording off hand)
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
