Hey everyone - I've been reading my live data on my Wagon and i notice my MAF readings at full throttle seem off... the G/s seem correct around 145 g/s, but the calculated engine load at MAX redline is 58%, when normal i believe is 85%+
I'm wondering what some potential causes are cause i do feel like the car has lost a little power
I've replaced a few things: Disa valve, spark plugs, filters etc..
Not sure how you are coming up with those numbers, but you can use testo to get realtime load and MAF through the BMW diag protocols.
https://www.bimmerforums.com/forum/s...ime-graph-view
BMW reports load in mg/str and your car should reach around 500+- mg/str.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Bluetooth OBD Piston app lolz
it reports 100% when i use it on my e38
Was a diagnostic scan performed? If so, codes displayed ?
Based on post#1, I suspect cat restriction.
Perform an exhaust backpressure test.
Post back with #'s displayed.
I havnt hooked up my AutoLogic to it for a full scan, but will do so.
ill do that test as well.
