Results 1 to 3 of 3
Thread: Broken gear selector wire
    Jul 2018
    Vancouver, BC
    1988 BMW 735iL
    Hello all,
    I fucked up pretty bad and snapped my gear selector wire when messing with the wrong bolt (trying to replace selector o-ring) on my 88 735 iL. The wire snapped off flush with the bigger metal sheath that it goes into. I saw a video (https://www.youtube.com/watch?v=iQt9I6siT3s) on soldering the two back together.
    First of all, is this a good idea? Second of all, should I open up the larger metal sheath with a metal grinder to get the remaining wire out or can I just solder the wire right back to itself.
    Any advice as well as further detail on replacing the selector o-ring (lol) would be greatly appreciated.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    you can get a new one : 16 CABLE NOISE ABSORBING 1 09/1987 09/1991 25161218349 $31.92, only in conjunction with SUPPORT NOISE ABSORBING ZF 1 09/1987 - 09/1991 24511218351 $32.71 https://www.realoem.com/bmw/enUS/sho...diagId=25_0051
    Soldering mit be possible. Cable housing ends you might get in a motorbike shop. The support noise absorbing is just a rubber piece, you might get a fitting rubber sleeve in a motorbike shop much cheaper.
    O-Ring change, here from a 5HP30, same procedure http://bmwe32.masscom.net/dutch740/s...ectorshaft.htm
    Hint: before you install the seal on the selector shaft, mask the selector shaft with masking tape, because often the lip seal is damaged when installing the seal.
    Jul 2018
    Vancouver, BC
    1988 BMW 735iL
    I still have hat rubber shock-looking piece. Also the link you posted was my guideline but the photos don't look like what i see beside the pan
  1. Problems with Automatic gear selector..........
    By John540i in forum 1983 - 1991 (E30)
    Last Post: 03-30-2004, 01:23 PM
  2. is there a Park (gear) signal wire on 94 325is auto?
    By ccblanket in forum 1991 - 1999 (E36)
    Last Post: 02-07-2004, 02:54 AM
  3. Gear Selector Rod Joint
    By ca415playa in forum 1992 - 1999 M3 (E36)
    Last Post: 07-09-2003, 09:29 PM
  4. gear selector light on auto stucked on P
    By cesspenar in forum 1991 - 1999 (E36)
    Last Post: 06-18-2003, 04:44 PM
  5. Gear Selector on Steptronic Tranms Lost
    By alexr in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-29-2003, 03:36 PM
