Results 1 to 3 of 3
Thread: New Used engine fault codes P0050 P0155
    Jul 2018
    Los Angeles
    2007 BMW 530i
    Hi! I drive 2007 BMW 530.
    Just had my engine replaced to a different used one. Once it was done new fault codes appeared P0050 and P0155 + Check engine light is on. Mechanic does not want to take responsibility, says he did nothing that could cause these problems. Can new engine cause these problems if it's bad?
    Thank you!
    Dec 2013
    Chicagoland area
    EXOTICS
    Check the fuse for the oxygen sensor heater circuit.
    Jul 2018
    Los Angeles
    2007 BMW 530i
    Replaced the sensor, codes cleared but now 5 cylinder misfiring. Compression, spark plugs and ignition coils are fine. Any thoughts what's going on? Thank you
  1. Quick Engine Fault Code Help...
    By mikeinsanmarcos in forum 1992 - 1999 M3 (E36)
    Last Post: 08-13-2006, 12:31 AM
  2. Engine Fault codes (where do i find what they mean)
    By speedhunter12 in forum 1991 - 1999 (E36)
    Last Post: 10-27-2003, 12:16 AM
  3. Car Won't Start No Engine Fault Codes...any ideas?
    By RRdawho? in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-26-2003, 03:44 PM
  4. Check Engine--fault code 1231
    By oldspiker in forum 1983 - 1991 (E30)
    Last Post: 09-29-2003, 12:24 PM
  5. Engine fault codes 41 and 45
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 10-21-2002, 04:07 PM
