Results 1 to 10 of 10
Thread: M62 throttle/idle question
    Fairfield, Connecticut
    '98 540i '01 540i 13 E70
    What would cause my idle to go up to higher RPMs while sitting there idling??? What is the proper idling RPM on an m62?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    IL
    2000 740i sport
    Quote Originally Posted by 300kplus View Post
    Id say proper idle is 590 rpm and around 150 extra if the AC is on.
    Sent from my SM-N910T3 using Tapatalk
    Quote Originally Posted by purplecty View Post
    Okay so I'm good there but intermittently she jumps up to 1500 and stays there and maybe goes up to like 1700 and comes back down 1500 and stays up in there until I rev her a couple times and she comes back down to "normal...
    Jan 2016
    Ca
    2001 525it
    Check for pending faults in the dme. Vacuum leaks starting?
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    On my 540i6, I can connect a scan tool and it'll tell me if the engine idle is following commands. If it's uncommanded changes, then there is an issue. I know it's not much help but it's worth looking at.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
    San Jose, CA
    1997 BMW 540i 6 speed
    Mine idles at 500 RPM, and with the A/C on, 600.
    There may be a vacuum leak, or a malfunctioning idle control valve.
    Quote Originally Posted by jclausen View Post
    DME?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    DME?
    BMW-speak for ECU. (you should know this by now).
    Yeah if there's weird mixture issues it can bump up like that. Also kicks up / down w the AC compressor going on/off.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Nov 2008
    M550iX, 540M-Sport, Scud
    Check your floor mats....seriously. If you are using non factory mats, or mats without the factory securing tabs, then the mats can slide forward and press against the gas pedal. Check and make sure this is not your problem. The easy check is remove the mats and go for a drive. I had an older Ferrari that was new to me at the time, and the idle would run fast. Tapping or blipping the throttle would drop the revs down....but was annoying. I checked the mats, and sure enough, that was the problem. I fixed it with some Velcro.
    2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
    Mar 2010
    ^^^^ this. To give a very specific E39 example, I had floormat interference cause weird idle stuff and phantom pedal & throttle body codes (I also separately had real throttle body codes, but it didn't help having the phantoms out there too!)
    2003 M3CicM6 TiAg
    Former:
  1. SOS M62 Throttle Body hose question SOS
    By E39540V8 in forum 1996 - 2003 (E39)
    Last Post: 04-06-2014, 08:05 PM
  2. M62 throttle body question
    By mxracer41 in forum 1996 - 2003 (E39)
    Last Post: 05-03-2013, 04:25 PM
  3. idle question slight surge in half throttle
    By driftin07 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-02-2013, 06:05 PM
  4. Throttle body question and rough idle.
    By Gentleman K in forum 1991 - 1999 (E36)
    Last Post: 03-09-2012, 02:20 PM
  5. M62('97) Throttle Cable Question w/Pic
    By RatedM3 in forum 1995 - 2001 (E38)
    Last Post: 05-16-2011, 09:04 PM
