Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: 530i die after 1km + start back after cooling down - solved, fusible link replaced
  1. #26
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by boy2nd View Post
    fusible link is in tight place , maybe i should remove the front seat and side trim ?
    Attachment 634852
    Attachment 634851
    Are you a Sumo wrestler?
  2. #27
    Jun 2017
    Indonesia
    E34 530i
    so, i finally remove the fusible link ,it says 80A , but in the forum says it has 50A i getting confuse
    Mini ANL fuse PNP to original holder
    Quote Originally Posted by ross1 View Post
    no, just regular skinny person LOL
  3. #28
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    according to the 1995 E34 wiring diagram US version page 0670.2-00 you see a 80A fuse called FO plus fuse F97 which does go to the front power distribution box X6400 B+ junction box. Nothing mentioned there about A.
    http://shark.armchair.mb.ca/~dave/BMW/e34/e34_95.pdf
    The pics from you looks like original parts, so use the same A as was installed originally in your car, maybe the E34 assembled in Thailand or Indonesia (knock down kits) were a bit different.
  4. #29
    NW suburban Chicago
    hiss by my window
    Ill post my chasis number and engine number , in Indonesia doesn't have a VIN , i already search in windshield , all 4 doors
    It's safe using a tube type fuse ? Or must be a mini ANL fuse ?, before it die the tachometer is jumping around
    Sent from my HM 1SW using Tapatalk
    Just noticed this picture, ostensibly the O2 sensor connections. Was there anything even connected here? Those terminals are dirty enough to alter the signal
  5. #30
    Jan 2005
    Japan
    no O2 sensor, see his post last month
    my car seems don't have a oxygen sensor , the 2 ports its in there but no wire / sensor connected
    That would mean the engine would run in basic value setting. There were some countries in those days where cat system was an optional extra and no O2 sensors were installed.
    To start the engine the O2 sensors are anyway not in use till they are at operating temperature.
  6. #31
    Jun 2017
    Indonesia
    E34 530i
    ~~~~Sorted Replaced Fusible Link~~~~
    Thank You Everyone
  7. #32
    Macon, GA
    '94 530iT/A|'95 540iT/6
    Nice anniversary bump! Glad you got it figured out.
  1. Replies: 22
    Last Post: 05-27-2017, 09:16 PM
  2. Replies: 3
    Last Post: 02-23-2017, 01:55 AM
  3. Car shut down; starts back after awhile
    By deylo in forum 1999 - 2006 (E46)
    Last Post: 04-30-2015, 09:54 PM
  4. died and wont start back up
    By HondaHunter325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-11-2009, 12:52 AM
  5. Key doesn't rotate back after starting car
    By gofastant in forum 1991 - 1999 (E36)
    Last Post: 05-31-2006, 01:38 PM
