I just replaced my steering wheel positioning sensor. I still have my code and all the three lights on the dash, Yellow brake light, traction control and Tire pressure. I can't get to code to go away. Do I need to reprogram the sensor? Also I turned my wheel all the way to the right and my power steering went out. It is going from bad to worse. Any help would be great here.
You need to take it to a good bmw independent shop and have them take a look, it sounds like your talking about the steering angle sensor. The sensor is not plug and play, it will need to be programmed and set. If that was what the real problem in the first place.
Yes it is the the steering angle sensor. I have the BMW reprogramming software I'm just having trouble getting it to program.
