Im having a misfire issue while driving with the RLTC on. Once I turn it off its fine.
Just to confirm to those using it, there are "48" teeth on ABS rings?
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
I had this issue. One of the transistors was burned out. You can measure impedance across the 3 pins of the transistor and when you find one that is different than the rest, replace that transistor. You can find the parts online still.
1999 M Coupe
48 teeth is correct for the e36
think I found the issue...the wheels were not assigned the correct corner. testing today
Did you also perform the calibration? (Plug in the dongle, do a u-turn etc)
So you managed to get it calibrated with the wheels assigned incorrectly? It's been a while since I did my calibration but the point of it is to let the unit learn where the drive wheels are, rotating differential rate etc. So it's surprising that it calibrated with the wheels being assigned wrong. I didn't see the laptop method but with the dongle it was pretty foolproof, with it indicating on the LED that it's happy.
Why did your settings change?
