Results 1 to 3 of 3
Thread: Temp gauge problem. Ideas?
    Sep 2015
    asdf
    m3
    After purchase i started a full restoration what just got finished. I drive the car but the gaugue does not work (i saw it working once). When i turn the ignition key it moves up a little bit. If i ground the sender the needle doesnt rise. I checked the wires with DMM from the connector of the sender to the temp gauge's grounding legs and the contiunity is fine. I disassembled the cluster. If i test the needle with a battery it only redlines when i push it through halfway with my finger (i tested another temp gauge with the same result). The SI board was repaired by an expert. He put new batteries on the board too but the strange thing is that the SI lights are blinking sometimes or not turning on. (1983, 635)
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    I'd rebuild it with a spare, unless you're handy with component repair. I've seen pretty extensive damage to board traces over the years from all sorts of causes. There are also upgraded SI boards that don't need batteries, but I don't have any recommendations. I've heard iffy things about Programa (here's their SI board) but haven't used their stuff yet.
    Maybe reach out to HitManX, he has a lot of experience with this sort of thing. I highly recommend his advice, he's a real credit to the BMW community, E23 in particular.
    Save the manuals!
    '08 128i 6MT, '86 635CSi 5MT (B32, Motronic 1.3, WBO2, G265, 18# FW, 3.46 torsen)
    Past projects:
    '96 318iS, sold 4/23 '90 535iM, RIP 1/23 '90 535iA RIP 6/22 '91 318i, sold 7/19 '97 M3 sedan, sold 11/18 '85 735i, RIP 2/18 '92 325iC, sold 7/16 '91 318iS, sold 6/16 '84 745i, sold 10/14 '82 633CSi, traded 9/12 '90 325i, RIP '87 325 sold '89 525i, traded '87 325iS, RIP
    Aug 2008
    Sydney Australa
    1x633, 1x E3 2 DR Racer
    Could it be the sensor? They are not expensive and can fail.
    1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
    1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
  1. Temp gauge problem :help
    By tommo in forum 1983 - 1991 (E30)
    Last Post: 01-12-2005, 07:36 PM
  2. Temp gauge problems
    By Kyle M in forum 1992 - 1999 M3 (E36)
    Last Post: 04-10-2004, 10:29 PM
  3. Installed my new SI board, still have temp gauge problem
    By TC535i in forum 1983 - 1991 (E30)
    Last Post: 10-22-2003, 10:27 PM
  4. Replies: 3
    Last Post: 02-05-2003, 12:52 AM
  5. Help Please -> Temp Gauge Problem?
    By JBoz in forum 1991 - 1999 (E36)
    Last Post: 10-06-2001, 11:10 PM
