Results 1 to 8 of 8
    Aug 2018
    Atlanta, GA
    2004 BMW X5 E53
    Question Different Tire Sizes lead to a ruined transfer case / differential - TWICE
    Looking to save a buck I had a set of used tires put on my E53. They installed the following:
    Front: 235/65R17
    Back: 255/65(or60?)R17 -- not sure of the aspect ratio because the car is STILL at the shop.
    I drove without any issue ( apart from an occasional whirring sound near the end ) for about 6 months.
    Then the transfer case went out so I took the car to the shop to have it replaced. 2 weeks later the new differential went out and it was back to the shop. Now they want to charge me again plus the pinion gear against the ring gear were both damaged.
    Obviously I should have not let the tire shop install different sized tires but I've seen that some X5s have different sized tires so I wanted to get the expert's (you all) feedback on the situation and how responsible I should be for the second set of repairs.
    Thank you in advance for looking in to this!
    Vehicle info: 2004 E53 X5
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    You can see from the owners manual...as well as the tire inflation chart on your driver's door/door jamb what the BMW recommendation is for tire sizes. Yes, you can use a staggered set-up but the BMW staggered wheels are also wider in the rear which accommodates the wider tire width and lower aspect ratio. The overall diameter/circumference should be within 3% of each other (basically the same rolling circumference).
    You left off the suffix of your X5 so don't know if you have the 3.0 or not...but the tire recommendations are the same as below for 17" tires. You can google "tire size calculator" to find out if the tire sizes you have mounted are within 3% rolling circumference of each other:
    Jan 2016
    Ca
    2001 525it
    I don't think the shop knows what there doing we rarely have to replace transfer cases. Are the parts used? And what is the thing about replacing the ring and pinion. There going down the rabbit hole.
    RI
    2008 M5, 1995 540i
    I dont see how the non standard size tires would screw up the transfer case, would be a first if true. I ran a non traditional size on my E70 for 2 winters with no problems, 245/50-18 instead of the stock 255/55-18.
    Current Cars
    2008 BMW M5 6 spd
    1995 BMW 540i 6 Spd
    2016 M4 Cabrio 6 spd
    2017 X5 35d MSport
    2017 i3 94ah Rex
    Former Cars
    2013 135i MSport Cabrio DCT
    2012 BMW X5 35d Sport
    2000 BMW Z3 2.8 Roadster MSport Impala Brown
    1992 BMW 535i 5 Spd
    2011 BMW X3 2.8i MSport Alpine White
    1995 BMW 530iA Artic Silver
    1986 BMW 635CSi Bronze Mettalic
    2009 Dodge Ram 2500
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    The idea is to keep the same rolling diameter difference between from and rear. Other than a speedo inaccuracy, it changes nothing. But if the OEM front tires are 15% smaller in rolling diameter than the rears, you need to respect that.
    2007 FJ Cruiser (best vehicle to date)
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Oct 2007
    Golden, CO
    17 Raptor|05 GTO|00 P38
    Running two different tire heights front to rear will definitely cause issues.
    Halifax, Nova Scotia
    2001 530i, 2007 X5 3.0si
    I'm not sure if this is a myth, but I've heard that running worn tires on one axle and new on the other can cause issues like this. Apparently it is that sensitive. That is why Discount tire (I believe) offers a tire shaving service, so you can actually match the wear of your old tires.... I'm just going to replace all 4 when I need to.
    Aug 2018
    PA
    BMW X5 4.4i
    Quote Originally Posted by ChrisMelnyk View Post
    Only really old 4WD systems can cope with different rolling circumference front to rear or side to side. (Land Rover, Jeep)
    Just about everything post 2000 will cause severe damage if there is a difference, that's why tire rotation is crucial to extending the life of the tires and time between changes. You must always change all 4 tires at the same time when buying new.
  1. different tire size and manufacturer for track day...
    By foler in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-09-2009, 02:14 PM
  2. Different Tire Size
    By kisig in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-19-2007, 09:15 AM
  3. want to get different tire size
    By KrazyRushin in forum 1992 - 1999 M3 (E36)
    Last Post: 11-06-2005, 01:06 PM
  4. Wheels are same size, but different tire sizes, is this ok?
    By dave is cool in forum 1992 - 1999 M3 (E36)
    Last Post: 04-30-2003, 09:39 PM
  5. Will different tire sizes mess up ABS or Traction Control?
    By Hellrot Sachin in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-26-2002, 05:31 PM
