Results 1 to 21 of 21
Thread: Auto dimming mirror on S54
    Feb 2004
    VA
    Just another public service announcement. Replace them.
    I had one in a car that barely see the light of day and it leaked. I didn't think these things leaked if they weren't sitting outside but they do.
    Luckily it was on a piece of plastic by the shifter (and not the upper dash) which is still annoying to source so I'll eventually take everything out and repaint.
    Do yourself a favor. Just get rid of that liquid filled POS.
    Feb 2014
    Galt,CA
    2002 M Coupe
    You're overreacting. If you go through the FAQ you will find that this is a known issue with a known cure. Once they have been rebuilt there are no further issues.
    Marty
    Feb 2004
    VA
    I wasn't saying it wasn't a known issue or that I don't know the fix, as I've fixed my other car's before. I was saying I'm surprised my second one (on a different car) leaked when it wasn't exposed to adverse environment conditions.
    Just a reminder to change them out regardless of whether yours is exhibiting any symptoms or not.
    I am speaking about the originals. Not any of the refitted ones.
    San Antonio
    Z3M Coupe & Roadster
    I'd keep an eye out on the ones redone as they still have the liquid in them. Maybe not right away but in the 5yrs and after I'd keep an eye on them.
    Bay Area, Killa Kali
    2002 M Coupe, 2019 F31
    Quote Originally Posted by jajou318 View Post
    Not if you buy a proper aftermarket replacement that uses conductive gel instead of liquid (such as the OE replacements). My rear-view mirror has not failed in 16 years but I just replaced it myself recently with a new gel cell unit as preventative maintenance. You can either DIY (what I did) or send it off to one of several companies that specialize such a repair.
    Yeeeeeeeee!!
    -2023 Honda Odyssey Elite
    -2019 F31 Individual (M-Sport, Prem, Exec, Track)
    -2004 Honda CRV
    -2002 S54 M Coupé
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    ...or you could just install the non auto-dimming mirror, which also provides added visibility due to the slightly wider profile.
    Non auto-dimming MZ3 mirror: 51162495571
    "You don't win silver....you lose gold."
    Feb 2014
    Galt,CA
    2002 M Coupe
    Quote Originally Posted by danomite View Post
    .... and contributes to the already big blind spot that cars entering an intersection from the right side hide in. Of course the solution is to mount either mirror up against the roof so that cars can't hide behind them. You lose a little distance due to the top edge being masked, but you will see the car on the right you were about to become acquainted with.
    Marty, who has tried every combination listed, now using high mount updated auto-mirror.
    St. Petersburg, FL
    2020 M2C
    Used e36 mirror for $17 works great for me.
    Bill
    2002 M Coupe. Steel Gray/Black.
    Do whatever makes you happy you feel me?! That's the beauty of having options as there's no right fit for everyone.
    -2004 Honda CRV
    -2002 S54 M Coupé
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    How do you high-mount the mirror? Just remove the mount from the windshield and move it up?
    I'm using an E36 mirror FWIW
    Feb 2014
    Galt,CA
    2002 M Coupe
    Quote Originally Posted by scenturion View Post
    One of the forum members used to make a modified mirror mount to accomplish this, but I don't think he has made any available in quite some time.
    Marty
    San Antonio
    Quote Originally Posted by CaliAgents View Post
    Yeeeeeeeee!!
    Ah, I didn't know they have a gel now! Sybesmas was one of the companies iirc.
    Yeeeeeeeee!!
    Oct 2014
    Rochester, NY
    1998 Z3
    Yeeeeeeeee!!
    How do you DIY this?
    1998 Z3 1.9L Dinan Stage 3.
    I purchased my replacement gel-filled mirror from www.mirrorjohn.com. He is based out of the U.K. and that's where it was shipped from.
    Here is his write-up that I followed, albeit with some different tools: http://mirrorjohn.com/How_To_Fix.php
    I recommend buying a cell phone disassembly kit (not shown) to aid in opening up the mirror housing. You definitely want to choose the right tool and take your time as you can easily scratch the housing, mangle the seam, break the fragile clips, or any combination of the above.
    Be extra careful with your utility knife when you remove the circuit board backing plate from the original glass. Take your time removing the original double-sided tape so you have a clean, uniform surface for the new double-sided carpet tape.
    Original glass on top, Mirror-John replacement on bottom.
    Circuit board and backing plate adhered to new mirror. Assemble the two housing halves back together and put that bad boy back in the car. Now you can sleep tight at night without worrying about that highly caustic fluid leaking all over your dash and console.
    Don't forget to put on your favorite slaps and put in work you feel me?!
    -2004 Honda CRV
    -2002 S54 M Coupé
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by MartyBtoo View Post
    Including this one?
    When I got my Coupe, I couldn't see anything behind me and was afraid to drive the car__much__until I put a proper mirror in. Note, I don't sit so tall in the seat that the stock mirror/stock location presents a problem (and with three cars that are virtually the same when sitting in the driver's seat, some commonality is required).
    I think this mirror came out of one of Mattel's Barbie cars!
    Jan 2016
    Ca
    2001 525it
    There is guy in Texas that fixes the self dimming mirrors for 100.00.
    Sep 2017
    Northeast
    2001 M Roadster
    Some of you guys posting about this guy or that guy who does it or sells it and only single link? Can you share who “the guy” is. We all know “a guy”, but apparently not “the guy”. Bottom line, I need to fix my mirror too . It’s not leaking, yet, but I have blue blob in the middle that does not go away.
    May 2010
    Rossmoor, CA
    1998 BMW Z3 1.9
    Yes, I'd like to know who "the guy" is in Texas. Please let us know. Thanks!
    Aug 2017
    Google "bmw auto dimming mirror repair texas", you find this: http://www.radar-mirror.com/Mirror_Repair.html
    99$
    Apr 2012
    Houston, TX
    2002 M Coupe
    I’ve sent 3 or 4 mirrors from previous project coupes to Sybesma’s Electronics.
    It ran $100 the last couple times.
    Mail your mirror in, include note with your contact info. They call you to confirm what you want done (replace OE liquid with new non-leak gel) and they complete it and mail it back. 100% success rate thus far.
    Sybesma's Electronics
    Phone: (616) 392-6911
    Toll Free: (800) 456-4265
    Fax: (616) 392-9885
    581 Ottawa Ave.
    Suite 100
    Holland, MI 49423, USA
    ___________________________________
    Always looking for my next
    ///M Coupé...
    Ive used Radar Mirror and Sysbema. Both have been great, I wouldnt hesitate to use either again
    PRICE CUT on ALL FABRICS
  1. E46 Electrical Schematic for Auto Dimming Mirror
    By JoeCinVA in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-11-2006, 07:59 PM
  2. Auto dimming mirror question (wire)
    By rmn in forum 1992 - 1999 M3 (E36)
    Last Post: 01-05-2004, 02:35 AM
  3. Homelink Auto Dim Mirror
    By CrayzeeM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-30-2003, 11:38 AM
  4. Rear view auto dimming mirror
    By Frederick in forum BMW Parts For Sale
    Last Post: 07-21-2003, 02:29 PM
  5. Auto-dimming mirror wiring help
    By jb325 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-06-2002, 11:57 AM
