Results 1 to 6 of 6
Thread: 2004 645ci 4.4 v8 loud whistle/scream noise after valvecover update replacement
    Aug 2018
    lawrenceville,GA
    Audi rs6
    Hello everybody , im kinda stuk on a friends BMW 645ci 2004 4.4l v8
    The Car had multiple oil leaks that i had to fix , also the valve cover on the passanger side was damaged and had to be replaced ....
    Oil leaks that got fixed : Oil pan gasket , Upper timing cover gasket passanger side , all o-rings and gaskets that are invovled , Valve cover gaskets , and both Valve covers are new too,
    also it got the new updated crankcase vent pipes ...
    after all the work got performt and the oil leaks got fixed , the car started creating a very loud screaming whistle noise at idle cause by a very strong vacuum that build up in the crankcase ...
    also the car dosent throw any codes and the rediness is completley set ... under higher rpm the noise disappears ( throttle opens and decrease the vacuum inside of the crankcase )
    im not sure but logical the vaccum shouldnt be that high because why is the car equipped then with a vacuum pump for the brake booster .
    hope anybody can help
    (sry for my englich , definetly not a native speaker xD )
    thank you already for any help or/and advice
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The crankcase vacuum should be 30 millibars or so (not much at all) - so if you have more than that you have problems with the pressure control valves (CCV/PCV) and/or the pipe work. So, have a read of this, this will take you through the crankcase ventilation system:
    https://www.meeknet.co.uk/E64/BMW_E6...eplacement.htm
    My BMW Repair YouTube Channel
    Aug 2018
    lawrenceville,GA
    Audi rs6
    damn , so i if that even fits for the n62 engine ... than they gave me the wrong parts because the pipve from the passanger side that goes directly into the intakemanifold has not pcv valve at all ... and i was already wondering all the time how it gets regulated ...
    Dec 2015
    UK
    04 BMW 645ci
    I'm guessing here but it sounds like you've been given the updated valve covers, to use these on a pre 06 car you'll need updated PCV vent tubes to go with it.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It certainly won't like having piping from the valve covers directly to the manifold without the PCV - there is a huge amount of vacuum available at the manifold at start-up.
    Jan 2016
    Ca
    2001 525it
    We had a car somebody brought in had a new right valve cover without the new updated breather pipe which also had the PDF valve in it, ran poorly till it was replaced. If you ever look up parts and the main part number all so says in conjunction with that means the part numbers listed below the main part number are all so needed.
  1. Loud whistle/screaming noise
    By louiee in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-05-2013, 11:58 PM
  2. loud whistling
    By blenderM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-24-2007, 12:09 AM
  3. m44 loud whistle after warmup, changed tensioner pulleys
    By krautcars in forum 1991 - 1999 (E36)
    Last Post: 10-19-2007, 11:10 PM
  4. Loud Whistling Noise
    By morristhecat in forum 1991 - 1999 (E36)
    Last Post: 05-13-2005, 06:04 PM
  5. Incredibly loud whistling, whining sound over 65 MPH
    By gr8full in forum 1991 - 1999 (E36)
    Last Post: 07-15-2004, 07:56 PM
