RM European Auto Parts
Results 1 to 12 of 12
Thread: Sudden drop in fuel pressure
    Feb 2010
    Norway
    97 bmw 320, 94 bmwm3
    I have a friend that is struggeling with a problem.
    The problem is that you let the car idle, the fuel pressure will be stable at 3.5 bar, then suddenly drop to 2.5 bar in 30 seconds, and stay there. Switch off the ignition and back on, and pressure is 3.5 bar again.
    But after 30 sec or so, its down to 2.5 again.
    Regulator and pump has been changed.
    Anyone have any inputs?
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Have the regulator and pump been changed prior to the issue appearing or after?
    "If you have integrity, nothing else matters. If you don't have integrity, nothing else matters." Alan K. Simpson.
    5spd E46 "3XX": 328i engine, 330i Intake and exhaust, CAI, 323i diff.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I'd question the gauge.
    PLEASE always tell us exactly what car we're dealing with...... (Maybe the pressure's actually SUPPOSED to be 2.5 bar....we don't know, if we don't know what car you're talking about.)
    Chris Powell
    BMWCCA 274412
    Feb 2010
    Norway
    He bought the car with a hesitatation problem.
    Checked the pressure, with the same result. With 2 diffrent gauges.
    Then changed pump and fpr, with no change in pressure.
    It sounds like the pump is suddenly dropping speed, when the pressure drops.
    But the pressure is really stable at 2.5 or 3.5 bar. It just drops suddenly 1 bar. Without fluctuating.
    Car is a subaru. Hope thats ok.
    Could it be some sort of speed controller for the pump?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Pumps typically run at a single speed. A sudden drop can be caused by any of the following:
    - a partially blocked fuel filter
    - a soft failing fuel pump
    - a blockage in the fuel line.
    I have no idea where the fuel pump is located in a subbie (Chris should be able to help!) but I’d listen to it to see if the noise it makes changes.
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Quote Originally Posted by s50b30 View Post
    Given what's in green it seems like this pressure drop is commanded by the ECU for some reason, like some sort of limp mode. Does the pressure drop after 30s EVERY time, even after a warm startup, or only after a cold startup (and then stays at 2.5 once the engine is warmed up?).
    I'm not knowledgeable enough to take it further at this point, but I'd say look at what changes in engine management conditions after 30s. Could be a table/table switch triggering this; for e.g. the pressure is at 3.5 as long as fuel management is being controlled by a "cold startup enrichment" table, and then drops.
    Dumb question maybe: is it really a problem if the pressure drops to 2.5? Or maybe it's supposed to be that way and the "hesitation problem" comes from something else? Does the pressure go up when pushing the throttle or is it stuck at 2.5?
    Jun 2002
    E39M5, E500 4WD
    Given that it's a Subie (I own one, for a winter beater, btw), I'd have to say you should throw a fuel filter at it. I mean, the damned thing sits right up there, facing upwards, in the engine compartment, and it costs about a quarter. (Sure, I'm exaggerating.)
    Um, if you'll be more specific about WHAT subaru, I'll look it up on Alldata and see what I can find. I just drive mine when the weather's really rough, don't work on it any more than I have to....
    Chris Powell
    BMWCCA 274412
    Feb 2010
    Norway
    Well. The regulator is 100% mechanical, so pressure should be the same regardless.
    Filter has been changed aswell.
    This turned out to be quite the headache.
    NW suburban Chicago
    hiss by my window
    Is there a vacuum hose on this Subaru FPR? Is it connected to the correct spot?
    Feb 2010
    Norway
    So after a little more research we found out that fuel pressure is too high the first 30-40 seconds. Not to low.
    The same things happens with the vacuum hose to fpr disconnected.
    Im even more puzzled now.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The FPR is bad, I bet. But, why would it revert to the correct pressure after 30 seconds of operation??? Time for a Haitian Voodoo Priestess!!!
    Chris, what’s your guess??
    Feb 2010
    Norway
    It did the same thing before changing the fpr with a new one.
  1. Replies: 59
    Last Post: 03-06-2016, 12:40 AM
  2. What could cause the fuel pressure to drop to ZERO?
    By LukeG in forum Forced Induction
    Last Post: 12-13-2008, 04:36 PM
  3. Fuel pressure dropping while sitting?
    By BIGRED in forum 1988 - 1996 (E34)
    Last Post: 07-04-2007, 01:27 AM
  4. Fuel Pressure drops
    By digger in forum 1983 - 1991 (E30)
    Last Post: 11-25-2005, 08:39 AM
  5. fuel pressure drop just before starting engine
    By Black Mamba in forum Forced Induction
    Last Post: 04-01-2005, 08:52 AM
