AC Compressor |
64 52 8 390 741 |
1 |
Used |
Alternator |
1 |
Used |
Alternator duct, boot |
12 31 1 735 915 |
1 |
Used |
Alternator intake manifold |
12 31 1 730 635 |
1 |
Used |
Bearing, con-rod, cap-side |
11 24 1 284 849 |
1 |
New |
Bearing, crankshaft, block-side |
11 21 1 706 847 |
1 |
New |
Bearing, flywheel pilot |
11 21 1 720 310 |
1 |
New |
Belt, AC compressor |
11 28 1 437 873 |
1 |
New |
Belt, water pump/alternator |
11 28 1 437 929 |
1 |
New |
Bolt, con-rod |
11 24 1 739 729 |
12 |
New |
Bolt, Crank Damper Main |
11 21 1 720 633 |
1 |
New |
Bolt, Crank Main Cap |
11 11 1 735 525 |
14 |
New |
Bolt, Crankshaft pulse generator |
13 62 7 545 338 |
1 |
New |
Bolt, Torx (Head x timing cover) |
11 12 1 720 731 |
1 |
New |
11 12 1 726 397 |
1 |
New |
Bracket, front O2 sensor |
11 78 1 744 154 |
1 |
Used |
Bracket, front O2 sensor connector |
07 14 9 157 161 |
1 |
Used |
Bush, con-rod, small end |
11 24 1 278 209 |
6 |
New |
Chain, oil pump |
11 41 7 576 915 |
1 |
New |
Chain, timing, cam x cam |
11 31 1 432 177 |
1 |
New |
Chain, timing, crank x cam |
11 31 1 432 176 |
1 |
New |
Crankshaft woodruff key |
07 11 9 951 480 |
2 |
New |
Dowel, VANOS x cylinder head |
11 12 1 726 238 |
1 |
New |
11 12 1 726 242 |
1 |
New |
Fuel Injectors |
13 64 1 703 819 |
1 |
Used |
Gasket, AC |
64 50 8 374 959 |
2 |
New |
Gasket, AC |
64 50 8 390 602 |
4 |
New |
Gasket, AC |
64 50 8 390 603 |
2 |
New |
Gasket, AC |
64 50 8 375 741 |
1 |
New |
Gasket, bottom end set |
11 11 1 740 981 |
1 |
New |
Gasket, cylinder head set |
11 12 9 069 861 |
1 |
New |
Gasket, head plug, ring |
07 11 9 900 244 |
1 |
New |
Gasket, oil fill cover |
11 12 7 526 447 |
1 |
New |
Gasket, oil pump pickup |
11 41 1 703 947 |
1 |
New |
Hose, AC compressor x evaporator |
64 53 8 377 678 |
1 |
Used |
Hose, AC condenser x compressor |
64 53 8 391 337 |
1 |
Used |
Hose, CCV vent |
11 15 1 740 393 |
1 |
New |
Hose, fuel inlet |
13 31 1 427 638 |
1 |
Used |
Hose, fuel inlet |
13 31 1 427 638 |
1 |
Used |
Hose, fuel return |
13 31 1 427 637 |
1 |
Used |
Hose, VANOS oil |
11 36 1 705 532 |
1 |
New |
Intake manifold |
1 |
Used |
Nut, camshaft bearings |
07 12 9 905 541 |
28 |
New |
Nut, cylinder head, earth strap |
07 11 9 922 038 |
2 |
New |
Nut, Engine Mount |
22 11 6 779 973 |
4 |
New |
Nut, exhaust manifold x midpipe |
18 30 1 737 774 |
6 |
New |
Nut, oil pump, shaft |
Pre-drilled |
1 |
New |
07 11 9 905 857 |
2 |
New |
Nuts, cylinder head, exhaust manifold |
11 72 1 437 202 |
18 |
New |
Oil filter set |
11 42 7 833 769 |
1 |
New |
Oil pump |
11 41 1 740 154 |
1 |
New |
Oil Pump, pick up tube |
11 41 1 703 930 |
1 |
New |
O-ring, fuel pressur regulator |
13 53 1 720 252 |
1 |
New |
13 53 1 720 251 |
1 |
New |
O-ring, radiator level switch |
61 31 1 361 249 |
1 |
New |
O-ring, VANOS solenoid |
11 36 1 703 713 |
1 |
New |
Piston ring kit |
2C5239 .016over |
1 |
New |
Piston ring kit |
11 25 1 405 782 |
1 |
New |
Piston wrist pin snap rings |
07 11 9 934 460 |
12 |
New |
Plug, crank holder |
11 11 1 714 541 |
1 |
New |
Plug, engine block oil galley |
11 11 1 268 539 |
2 |
New |
Plug, freeze |
11 11 1 714 712 |
7 |
New |
Plug, freeze (head front) |
07 11 9 937 293 |
1 |
New |
Plug, freeze (head rear) |
11 12 1 733 403 |
1 |
New |
Plug, radiator drain |
07 11 9 919 146 |
1 |
New |
Plug, screw (head) |
11 12 1 703 712 |
2 |
New |
07 11 9 919 031 |
1 |
New |
07 11 9 919 112 |
1 |
New |
Rubber grommet (CCV) |
13 41 1 733 217 |
1 |
New |
Secondary air pump |
1 |
Used |
Sensor, Camshaft pulse generator |
12 14 1 703 221 |
1 |
New |
Sensor, Crankshaft pulse generator |
12 14 1 709 616 |
1 |
New |
12 14 1 709 616 |
1 |
Used |
Sensor, cylinder head temp |
13 62 1 703 993 |
1 |
New |
Sensor, intake manifold air temp |
13 62 1 739 510 |
1 |
New |
13 62 1 725 323 |
1 |
New |
Sensor, Knock |
12 14 1 703 276 |
1 |
New |
Solenoid, VANOS |
11 36 1 703 720 |
1 |
New |
Spark plugs |
12 12 9 069 877 |
6 |
New |
Starter |
12 41 1 740 379 |
1 |
Used |
Studs, cylinder head, exhaust manifold |
11 12 1 744 057 |
18 |
New |
11 12 7 593 376 |
2 |
New |
Studs, cylinder head, intake manifold |
07 12 9 908 122 |
7 |
New |
Studs, VANOS x cylinder head |
07 12 9 908 102 |
3 |
New |
07 12 9 908 135 |
1 |
New |
Switch, Oil pressure |
12 61 7 568 480 |
1 |
New |
Switch, temperature, radiator |
61 31 8 363 677 |
1 |
New |
Tensioner, timing chain |
11 31 7 838 675 |
1 |
New |
Tensioner, timing chain, cam x cam |
11 31 1 738 700 |
1 |
New |
Tensioner, timing chain, guide |
11 31 1 726 480 |
1 |
New |
11 31 1 703 717 |
1 |
New |
Thermostat |
11 53 7 511 580 |
1 |
New |
Thermostat housing |
1 |
New |
1 |
Used |
Throttle body |
1 |
Used |
Valve keepers |
11 34 1 461 405 |
48 |
New |
Valve, crankcase ventilation (CCV) |
11 15 1 703 484 |
1 |
New |
11 15 1 703 484 |
1 |
Used |
Valve, Idle Control (ICV) |
13 41 1 744 713 |
1 |
New |
Valve, oil non-return to head |
11 12 1 735 180 |
1 |
Used |
VANOS diaphragm spring |
11 36 1 403 550 |
1 |
New |
VANOS rebuild |
Beisan |
1 |
New |
VANOS sprocket nuts |
07 11 9 900 910 |
3 |
New |
Water pump |
11 51 7 527 799 |
1 |
Used |
Wire Harness - Engine |
1 |
Used |
