Noticed oil consumption and burning smell this morning never had issues with the car yet other than coolent tank and Intake boots which were replaced car also as a slight whine noise about 2k rpm hoping to fix the oil consumption issue ASAP need help diagnoising and fixing problem! Small hose crack by the oil filter
Possibilities:
CCV valve/hoses, Valve cover gaskets, Vanos hoses/Banjo bolts, Oil filter housing gasket, all are common oil leak locations.
The burning smell is usually caused by oil dripping onto the exhaust manifolds, due to leaking vcg above them.
