Results 1 to 25 of 28
Thread: 540i overheating
    Mar 2018
    ct
    540 m sport
    540i overheating
    Recently I installed a new radiator along with an electric fan.
    The cars KTEMP was running around 105 around town and 101 on the highway. Until today. While idiling at a mcdonalds it hit 119/120. I shut it right off.
    The electric fan is always on VIA a switch and fastened straight to the radiator. It is a 16 inch 2500 CFM fan.
    Any ideas?
    At this point I just want to get rid of the car as it has 160k miles and needs the chains done. I can't daily this car any longer.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Need more info........
    What's your coolant level at when the engine is stone cold?
    Sure you don't have any leaks?
    Does you Aux fan work?
    If you don't use the AC does it still overheat?
    Dec 2012
    Philly Suburb
    2002 BMW 540iA
    Probably bleeding issue, try bleeding again.
    San Jose, CA
    1997 BMW 540i 6 speed
    Bleed Cooling System BMW method
    On your I6, you need to raise the front end of the car up as high as you can to get the air to the front of the engine.
    Cooling system bleed procedure (E39)
    - with cold car
    - top up coolant to proper level (even slightly higher will not hurt at this stage)
    - leave rad cap loose
    This stage bleeds air trapped in the heater system.
    - turn on ignition switch to position 2 (no start)
    - set temperature selectors on the climate control to max temp.
    - manually set the fan speed to low (lower end of speed range)
    - start engine (check that climate settings have not changed)
    - after 5-10 seconds of running rev the engine 3-4 times to about 2500 RPM - hold there for about 5 seconds each time.
    - shut off engine (should not run for much longer than about 30 seconds - you just want to shut if off before it starts to generate any heat and expand the coolant).
    - inspect the coolant level and top up again if necessary.
    - tighten the coolant fil cap.
    This stage bleeds air from the engine, rad and fill tank.
    - now warm up the engine (drive a bit if you wish)
    - with engine running CAREFULLY / SLOWLY open the bleed screw. Hold a rag around the area to prevent any excess splashing. Keep the screwdriver in the slot of the bleed screw so you can close it quickly.
    - you should have some air/steam escape - progressing to some bubbles of coolant.
    - as soon as it progresses to the stage where you are seeing liquid coolant come out then close the bleed screw. Do not over tighten - it is all plastic threads and you can easily turn too far at which point the screw jumps back a thread and you have to re-tighten. Just make it snug with all coolant stopped.
    - when the car is cold again re-check the coolant level and top up again if necessary.
    NOTE - some of the 6 cyl models have 2 bleed screws - the second one is near the thermostat. In that case you should bleed at both locations (one at a time)
    You may have to repeat the bleed procedure 1 or 2 more times over the next week. Can "probably" skip the stage for the cold start bleeding of the heater system.
    If the level continues to fall below the correct level then have the system fully pressure tested - explaining to your service manager what you have already done.
    It is very important that all leaks be sealed so that the system can operate at full pressure. The engine computer is programmed to keep the coolant temp at about 108C at "most" times (there are exceptions) and the only way it can maintain that temp is if the pressure can be maintained - system fully sealed.
    Mar 2018
    ct
    540 m sport
    When its cold its a half inch below the fill line. The car keeps overheating when driving and then when i hit traffic or start city driving. The electric fan is stronger than the oem engine fan i believe. The fan seems to be blowing in the right direction. I bled the system and nothing but coolant comes out the bleeding hole. Very stuck here not sure what i should do. Could it be a thermostat problem? Should I try to put the engine fan back on?
    I Have the m62tu.
    Mar 2018
    ct
    540 m sport
    Any other suggestions?
    Update:
    Bled the whole system again. I started it up and this happened: Is this normal?
    Pictures:
    When car is on
    https://drive.google.com/open?id=1hu...a-1kZ2jj-Rvucj
    When ignition is turned off:
    https://drive.google.com/open?id=14q...xDx_6wVViEpLEJ
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Have you run the car with the climate control temperature set to max while you were bleeding it?
    Sent from my G8141 using Tapatalk
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by upbeatgfx View Post
    Update:
    Pictures:
    When car is on
    Not enough information. Are you saying...
    A. First pic is when cold and second is after it gets hot and is shut down?
    or
    B. It goes to the full-red-rocket mode as soon as the key is shut off?
    or
    C. You shut it down, then after some span of time it goes red-rocket...?
    Its normal for coolant to expand when hot. So A & C (post-shutdown heat soak mode) are kinda normal.
    If your t-stat is stuck closed - or partially closed - or intermittently sticks partially etc. etc. - that easily could display such a symptom. Is the t-stat original? They crap out for sure. You can do the 88C non-MAP one but if you're really just going to dump the car soon you may not want to spend the cost / effort...
    I like you mentioned fan direction BTW, there's def cases of e-fans being put in the wrong way causing all kinds of weirdness (typically stays perfectly cool standing still but at low speeds suddenly overheats...)
    Radiator Brand? "Sketchy Joe's Discount House of Radiators"? Or dealer part?
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Mar 2018
    ct
    540 m sport
    or
    or
    Not sure if the thermo is oem, I bought the car with 140k on it, now at 160k
    Im going to do valve cover gaskets and chains so ill replace the thermo maybe then?
    Do you have a part number for that 88C or a thread?
    For the electric fan i run a flex-a-lite it was $100 so not a cheapo.
    link: https://www.jegs.com/i/Flex-A-Lite/4...xoC1A8QAvD_BwE
    Radiator brand: orileys (I had a warranty.) I want to try an all aluminum radiator but cannot afford $500. I heard you can use the ebay aluminum ones and cut the clips off and use hose clamps.
    At this point i need to keep the car and daily it because I dont have enoguh money for a new car (only 18.)
    The car ran fine today until I got home off the highway and at city speeds it hit 106C, when i idled in my driveway it overheated at 117C Not sure what the problem can be. It slowly goes up. (not enough airflow?) when the aux fan and my custom electric fan is running i dont feel any air coming out of the grille (fan wrong way?) The temp isnt just shooting up randomly when driving but it creeps slowly when idling after driving.
    When running in driveway after driving 3 miles:
    https://drive.google.com/open?id=1Iv...I8-JrT8eWgO8jh
    Another instance after driving 3 miles to work:
    https://drive.google.com/open?id=1ab...1hu3Ka6fBQjRta
    it cooled down though:
    https://drive.google.com/open?id=1Ub...2LpXYTUhiTbSZW
    Ignore the service light LOL!
    Mar 2018
    ct
    540 m sport
    car still over heating kinda. while driving on the highway (50 mph and up) coolant temp stays at 101C-105C. When going to a red light it can hit 106-110. After getting home from a drive and pulling into my driveway it hits 117 and wont cool down. Thinking it can be thermostat or the electric fan
    JimLev's Avatar
    Sundance Mesa, NM
    What are you using to turn on your Summit fan? That's a good fan, I'n using the straight blade version.
    Is your Aux fan working and when your temp hits 115 or so is it running.
    If you want to throw parts at it I'd start with the t-stat.
    Mar 2018
    ct
    540 m sport
    The aux fan runs whenever it wants.
    Im looking to do the 88C thermostat conversion, what do you do with the heating wires since there is a dme block off on the 88c?
    My fan is running through a switch, i basically always have it on. I also have a thermo switch that i need to install while i do the thermostat conversion. It will turn the fan on at 185C.
    Mar 2018
    ct
    540 m sport
    ordering the 88c thermostat today, any other reasons this can be happening? electric fan not strong enough??
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    I would pressure test the cooling system before buying anything.
    Sep 2015
    Mankato, MN
    1999 540i
    Did you replace the expansion tank when you changed the radiator?
    I had an issue like this with an aftermarket exp tank. Put the original back on and no more issues.
    A real head scratcher what was actually happening, but one symptom was when I took off the radiator cap on a cold engine, the bobber was down at the proper level, but would then slowly rise all the way up. Musta had some air trapped somewhere that I could not bleed out, no matter what.
    Next time I won't cheap out on an unknown exp tank.
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Put the mechanical fan back in. We can’t tell if he has other odd wiring issues, but it occurs in traffic/still. he says 540 / m62, but someone chimed in I6. I have a v8, and a v12 e38, no cheap cooling parts - Nose up - like on ramps, heat on high, high fan, fill it slow, start and bleed.
    Mar 2018
    ct
    540 m sport
    didnt replace the expansion tank but the levels keep dropping but no viable leaks in the system.
    Quote Originally Posted by Mach540 View Post
    the fan is always on so i know its running, and its running fast. ill put the fan back in to see what happens. the wiring is right i checked it 3 times just to make sure.
    Mar 2010
    I think fans running wrong direction or blades on wrong way.
    Try a puff of talcum powder while only the aftermarket fan is running. See which way it blows.
    2003 M3CicM6 TiAg
    Former:
    Mar 2018
    ct
    540 m sport
    Fan is in the correct position, I put a tee shirt in front of the car, blew off the hood. with only my e fan running.
    Mar 2010
    What?!? tee shirt in front of the car should be sucked into the grill. Did you put it on so it blows forward?! It needs to suck air from the front and blow it backwards!
    2003 M3CicM6 TiAg
    Former:
    Nov 2016
    NY
    +1 GG is right
    Nov 2016
    NY
    Yes it has to pull air in thru the radiator. That is why not to mess with what the German magicians gave you, if you are a noob.
    Apr 2015
    paradise
    the shinny one
    I have found that this post to be highly entertaining...
    please don't allow it to end so quickly.
    Mar 2010
    Shoulda caught this before. Lol. Air ain’t supposed to come OUT the grille Beavis!
    2003 M3CicM6 TiAg
    Former:
    Mar 2018
    ct
    540 m sport
    oh im retarded the wires where going to the power and ground to create a pusher fan not a puller fan.... I dont understand what I was thinking that day. I need to log off for a little to fix this embarrassment.
  1. '95 540i overheating, 1/2 radiator cold
    By Somethingelse in forum 1988 - 1996 (E34)
    Last Post: 10-09-2010, 09:54 PM
  2. 540i Overheating at Idle
    By P11 in forum 1996 - 2003 (E39)
    Last Post: 07-22-2010, 01:25 AM
  3. 91 540i Overheating
    By gfuller40 in forum 1988 - 1996 (E34)
    Last Post: 07-01-2010, 12:06 PM
  4. 540i overheating issue...
    By FinalBoss in forum 1996 - 2003 (E39)
    Last Post: 08-18-2008, 01:24 PM
  5. E39 540i Overheating!!! Help Me!!
    By m3amg43 in forum 1996 - 2003 (E39)
    Last Post: 05-03-2006, 07:20 PM
