The motor I built has a 325i head (885, IIRC). I'm wondering if the SuperSprint headers for my 323i will fit? I know they'll bolt on but are the ports bigger on the 325i head?
1972 BMW 2000 touring (restoration in progress), 1982 Alpina C1 2.3 (restoration in progress), and a 1992 BMW M5T (DD)
my restoration blog: https://www.alpinac1.com/
Everything I've read, Josh, is that the 885 just "flows better" but there isn't a difference in port size... i scoured the interwebs, looking for anything.
That being said, do you have access to your 885 and 200 head? you could measure the openings and see for yourself. If not, i have access to both also... with the bonus knowledge of what the exhaust port size is of a 731 head!
Past, Present, and Future
1974 BMW 2002tii (RIP)
1995 BMW 325is w/ FULL S50 swap, track prepped (SOLD)
1988 BMW 325ix Zinno/Black (RIP)
1988 BMW 325ix Alpine/Black (Sold)
1988 BMW 535is Alpine/Pacific Blue (Going Away...)
1982 BMW 323i (Current Project/Paper Weight)
2003 BMW 325i Sport Touring (Daily Driver)
I can't find anything on the web either. I looked at realoem first, before posting, and the gaskets I find are different-- the 325i ones have heat shields, may be same diameter though!
The freshly built motor is now in Sacto, so I can't simply compare. If you could, I'd appreciate it. Should have done this while both motors were here. Duh!
I see realoem actually lists them as changing over in 04/82, with the very late production e21 323i sharing the e30 325i gaskets and the earlier e21 323i sharing gaskets with the early e30 320i and 323i for a special emissions manifold, probably because the heat shields wouldn't clear it.
I can confirm the intake ports are all different on the 200/731/885 head though.
The 323 Supersprint headers work just fine with the 885 head. I "gasket matched" the ports on the exhaust side to the 325 gasket
No issues, no leaks.
Jeff
