Results 1 to 9 of 9
Thread: Another hvac repair
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Another hvac repair
    After reading up on the hvac repair (thanks hitmanx) I have decided to start tearing into mine.
    The buttons all seem to work and most functions are actually working but I have heat all the time.
    The heater valve does not hold vacuum so that will be my first place to start. I removed the hose and it doesnt seem like I am getting any vacuum from the red line when the dial is set to cool.....should I be concerned with this now or wait and see what happens after the valve is replaced?
    Also can the heater valve be rebuilt like the others or is it different inside?
    Thanks in advance for the help, I have learned a lot through searching this forum.
    Sent from my SM-G955U using Tapatalk
    Dec 2017
    Jackson Mi
    E21, E30, E23
    I went through the tests and troubleshooting from bmw and it looks like all temperature sensors are ok.
    The heater valve will get vacuum when the blower is switched to the off position, but still remains open (no vacuum) when the blower is turned on and the temperature selector is all the way down.
    I will continue to troubleshoot and see what I find......
    Dec 2017
    Jackson Mi
    E21, E30, E23
    I was about to give up but I thought I might as well try any part I can from my parts car....It works! Had to replace the control unit under the drivers side. Works like new, now I just have to fix leaking pods......
    Jun 2018
    MT View, HI
    98 318ti, 80 733, 76 '02
    Alright. Gotta love parts cars!
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Quote Originally Posted by TowJamma View Post
    If only it had a working heater valve. At least it has a few good parts. I had to drive 5 hours each way to get it but I have already robbed the transmission and now this! I paid $400 and I'd say it doesn't owe me anything now.
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    Two E23 parts cars. You might get lucky with a phone call. https://www.specializedgerman.com/us...ries-e23-parts
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    Jun 2010
    TX
    1983/84/85 745i
    I recommend a new heater valve, it is plastic.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Dec 2017
    Jackson Mi
    E21, E30, E23
    Thanks for the response I will get one coming. Most of the other pods are holding vacuum for now.....I will probably go through them this winter when I need a good project to keep me busy.
    Jun 2010
    TX
    1983/84/85 745i
    Single tit ones are easy to rebuild. Duals are a pain, Pavel knows how. I just replace duals.
    Defrost, cowl, face are your duals with ACC.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
  1. another pixel repair question
    By jr1966 in forum 1996 - 2003 (E39)
    Last Post: 06-15-2010, 10:17 PM
  2. BMW pay to prevent another subframe repair
    By myredzed in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-29-2009, 05:27 PM
  3. Another HVAC relocation thread (with a twist)
    By rockytt in forum 8 Series (E31)
    Last Post: 04-13-2009, 11:04 PM
  4. Another HVAC question
    By cdnalpina in forum 1988 - 1996 (E34)
    Last Post: 02-03-2009, 08:10 AM
