Results 1 to 2 of 2
Thread: Help! My 2006 wouldn't shift into drive, then gave "trans failure" message
    Sep 2017
    Chicago IL
    1995 740iL
    I've had this 2006 750Li with 54K miles for 4 months. I tried to shift into reverse or drive after the car was off for 5 minutes, would not engage gears and display would bounce back to Park each time. I tried to select a gear 10 or 15 times, then shut if off, turned it on, and this time it hesitated then jolted in reverse. Drove normally in Drive for a few miles, then displayed "Transmission Failure" message "drive cautiously in D3, D5" or something similar.
    Am I fucked? My 1995 with 160K e38 has had Trans Safe messages occasionally over the last 10 years but it has always recovered after 10 minutes or so, maybe because of weak battery.
    There was no history when I bought the car and I could not locate which dealer serviced it. It does not have the 2 to 1 gear bump. The shifts are more noticeable than on my 1995 e38, but I attributed that to more power of the e65.
    Oulu, Finland
    See my sig
    Seal between valve body and transmission broken? Read codes...
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
  1. Shifting from Drive to Sport 4 at high speeds/high engine revs
    By christos3000 in forum 1988 - 1996 (E34)
    Last Post: 06-22-2004, 04:36 PM
  2. Transmission slow to shift from Drive to Reverse, and visa/versa
    Last Post: 06-22-2004, 02:34 PM
  3. Replies: 10
    Last Post: 02-17-2004, 01:19 PM
  4. Need help w/ wiring retrofit illuminated shift knob!
    By Micah D. Cranman in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-22-2003, 02:12 PM
  5. need help designin a logo for shift knob
    By rflores2323 in forum Off-Topic
    Last Post: 03-07-2003, 11:01 AM
