hey guys I pretty much mess up.
long story short I was getting a fault code:
Code:
6E4F
Description:
DSC: control unit: pump activations
so I went to INPA and under UFI I noticed my DSC is showing 000000 for VIN number.
for some reason I went to WinKFP and decided to flash the DSC with the VIN number.
when I flashed it i got an error at the end:
Error 211:
Error on flash programmingl
Code 2080 Programming state invalid.
now I'm getting all sorts of fault in the system related to DSC.
what do i do?
What exact interface were you using?
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
So I ended up fixing this issue. I was missing some settings in WinKFP config and was able to successfully flash it.
only problem I'm getting now is the original fault code
Code:
6E4F
Description:
I tried resetting the fault code but it still comes back and on my dash and nav screen i get ABS malfunction. I get all 3 lights lighting up. brakes abs dsc.
