Results 1 to 9 of 9
Thread: Rough Running After Replacing Timing Chain Sensor
    Jan 2015
    Bluffton, South Carolina
    1997 BMW 840 CI
    I cannot get the cap off the diagnostic connector. I did a few things this weekend. Replaced Vapor Canister, Timing Chain Tensioner and the Timing Chain Sensor. Now the car is running rough and has no power under acceleration - it barely moves when depressing the accelerator. Do I have a faulty timing chain sensor?
    Toronto, Canada
    BMW 850CSi
    The diagnostic cover comes off by twisting counter-clockwise 1/4 turn then slides straight up.
    Sounds like you’re in LHM (running on 6 cylinders). Perhaps you forgot to reconnect something (MAF, etc)
    Sep 2011
    Vancouver Canada
    '91 850i, E39 & E46 Cars
    Dr.T - note that Jolo has a 1997 840- V8 E31, not an 850 V12, so not running on just 6 cylinders. Could be that the MAF connection is not secure, though.
    /Henry
    Jan 2015
    1997 BMW 840 CI
    Thanks much. I'll check the MAF. I had the diagnostic cap off last month to diagnose my Timing Chain Sensor and the O2 Sensors, but for some reason, the entire unit is twisting with the wires below which are already fragile. I will have to play with it some more. The car ran great after replacing the O2 sensors so it has to be the MAF. I believe the vapor canister pipe vents down and is not connected to any hose. Is that correct?
    Thanks again for the quick and helpful responses.
    Kind regards
    Joe
    Jan 2015
    1997 BMW 840 CI
    Thanks you were correct. I was twisting from the top of the cap rather than the knurled ring below the cap. 1/4 counter turn did the trick. No fault codes. I will recheck all my connections this evening Thanks again
    Jan 2015
    1997 BMW 840 CI
    Its a vacuum leak. I took the air induction off and noticed the center nipple on a t fitting by the dip stick has no hose attached . Cannot find the missing hose, but once I do, problem solved. Any ideas what hose connects to it. Tomorrow Ill put the car on the lift and see if I can find it.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It doesn't attach to anything on any country variant except for the German one - where the centre spur connects to a disturbance valve that is used for their 'smog' test to introduce air.
    Your one should have a cap fitted - more information here:
    https://www.meeknet.co.uk/e31/E31_84..._Tick-Over.htm
    My BMW Repair YouTube Channel
    Jan 2015
    1997 BMW 840 CI
    That's it Timm. I must have knocked it off when I dissembled the air intake. I found under the car a small piece of hardened rubber that looks to be part part of a plug. Thanks Timm, you saved me a lot of time and grief . And thanks to Henryc and Dr.T, very much appreciated.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If that one has failed you can be the other three have! Two on the PCV and one under the throttle body......
  1. Replies: 16
    Last Post: 04-30-2017, 09:20 AM
  2. Help with E53 X5 4.6iS rough running after timing chain replacement
    By Murf540iT in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 10-08-2014, 07:00 PM
  3. rough running after replacing spark plugs
    By stickerbush in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-26-2013, 02:04 PM
  4. 2000 540 after the Timing Chain Guide replacement
    By pinnaclepike in forum 1996 - 2003 (E39)
    Last Post: 05-21-2012, 02:22 AM
  5. Problems after having timing chain replaced
    By M3Cosmos in forum 1992 - 1999 M3 (E36)
    Last Post: 08-09-2007, 09:36 AM
