Results 1 to 8 of 8
Thread: Will an e28 cluster fit an e23?
    Jan 2012
    Vancouver, BC Canada
    1985 Mercedes 300SD
    So my cluster is in a bad way, the batteries blew up long before I got the car and seems to have eaten through everything. I have been slowly bringing the some of the gauges back, but I'm thinking a good cluster would save some time. It seems the e23 clusters demand big $$$ on eBay, so I was curious if the e28 cluster, or at least the innards were comparable with my 733i as they are much cheaper.
    1983 BMW 733i My current project (or at least one of them)
    2003 Volvo V70 5 Speed Current Daily Driver
    1993 300TE 4Matic Project wagon -sold
    1997 E290 Turbo Diesel Wagon -traded for above, an amazingly comfortable car to drive, great drivetrain, but the rust, oh my god the rust
    1992 BMW 525i -traded in
    1990 Silver 300TE -Sold Loved the wagon, hated the M103
    1985 Grey 380SE Diesel Conversion, 2.47 rear end, ABS -Sold, really should have kept this one
    1979 Silver 300D "The Silver Slug" -Sold
    Jan 2015
    Somewhere,USA
    1985 BMW 735i
    Try looking on realoem.com and enter your VIN to pull up what was fitted to your car. Then check the details of the part number and it will tell you what else it fits. The cluster housing itself, will not fit. That I do know. The circuit board that the instruments mount to could possibly be the same. probably on the tach. not sure on the speedometer and on the center cluster.
    Quadratechtown, PA
    5, 7, 4x4
    The main guts, tach and speedo will swap, I haven't been in the E23 cluster recently enough to know about the SII board or other parts will swap. Check per above to see.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Pretty sure the SI boards are the same, like 90% sure. Late cars have a different board. I am like Keith, been a while since I tore one down.
    Entire thing will NOT swap. Speedo and tach will, to confirm.
    US and ECE cars have different SI boards, something with the ground.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Jan 2012
    1985 Mercedes 300SD
    Thanks all for the info, the main and SI boards would be the big two I'd be interested in swapping, so that's great news.
    Quadratechtown, PA
    5, 7, 4x4
    Looking at realoem it appears the main board, conductor plate, is the same for E23/E28 for the 82-86 e28 US 535i and a bunch of E23s So you might be able to do a rebuilt with collected parts.
    Jan 2012
    1985 Mercedes 300SD
    thanks
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    The entire assembly should swap over on later clusters.
    I have multiple E23/24/28 clusters, and the entire rear assembly will just swap over.
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
  1. Will E28 rims fit an E36??
    By Nitro BMW in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-07-2008, 11:11 AM
  2. 3.46 from an E28..will fit?
    By purepump in forum 1992 - 1999 M3 (E36)
    Last Post: 08-25-2005, 04:00 AM
  3. Will E46 M3 Gauge cluster fit on E36?
    By bimmer328is in forum 1991 - 1999 (E36)
    Last Post: 10-11-2004, 02:10 PM
  4. will E28 wheels fit?
    By funkmasta in forum 1987 - 1991 M3 (E30)
    Last Post: 06-03-2004, 11:32 AM
  5. Will an M roadster cluster fit in a E36 M3?
    By Ali in forum 1992 - 1999 M3 (E36)
    Last Post: 01-27-2003, 08:51 AM
