EVERYTHING - $225 SHIPPED!!!
Here is what I have leftover from parting out a couple of motors. Prices are a starting point for negotiations. Generous discounts for buying multiple items. Most of the parts have been degreased and are relatively clean. Let me know if you have any questions.
Paypal is breakmywallet@outlook.com
Cam followers - $100
VANOS w/actuator (Besian seals) - SOLD
4x ignition coils (Bremi) - $30 for all 4
Idle control valve w/hoses - $30
Ignition coil harness - $20
Throttle position sensor - $20
VANOS high pressure line (updated version with 2 tabs) - SOLD
Starter cable - $10
valve cover (hot tanked and clean) - $75
PCV - $15
Thermostat - $10
Thermostat housings (blasted and cleaned - $25
Oil pump sprocket - $20
cylinder head timing chain guide (one on top) - $10
late model air rail (09/04+) - $40
fuel line/FPR vacuum line - $10
set cam follower clips - $15
intake cam sensor - $30
right side plastic lower timing chain guides - $5
rear main seal housing - $10
front timing chain cover - $20
LUK clutch disc - $10
pr front O2 sensors - $30
crankshaft timing sprocket - $50
AC compressor bracket w/ belt tensioner - $15
water pump pulley - $5
oil line from PCV to oil pan - $10 (pre-2003/non-AN fitting end and needs rubber hose replaced)
OE fan blades - SOLD
Starter - $40
Water pump - $50
Pass side engine mount - $20
Driver side engine mount - $20 (from SMG but will fit a manual)
Water pipe - $10
Other stuff...send an offer
SMG pump bracket
Camshaft spline flange
Thermostat housing bracket
Wiring harness bracket for VANOS actuator
Oil cap
VANOS oil pressure regulator
Timing sprocket bolt ring
4x Exhaust valves
Bracket for O2 sensors that bolts to valve cover
Timing chain
Oil pump chain
Intake manifold oil drain line (partial for SMG)
Intake manifold oil drain line (partial for 6MT)
Thermostat
Thermostat housings
Oil pump sprocket
fuel line/FPR vacuum line - No Picture
set cam follower clips - No Picture
Intake cam sensor
Right side plastic lower timing chain guides
Rear main seal housing - No Picture
Front timing chain cover - No Picture
LUK clutch disc - No Picture
Pr front O2 sensors - No Picture
Crankshaft timing sprocket
water pump pulley
Oil line from PCV to oil pan (pre-2003/non-AN fitting end and needs rubber hose replaced) - No Picture
Starter - No Picture
Water pump
Water pipe
SMG pump bracket
Oil cap
4x Exhaust valves
Timing chain
Oil pump chain
Differential 3.62 ratio?
