Results 1 to 5 of 5
Thread: Windshield Wipers-New Twist on Old Problem
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    After extensive searching, I'm unable to find solution. Wipers do not park, unless car sits for long time, e.g. overnight, then when I depress wiper lever, it parks. It stays parked until i use again. Then the same. I checked relays & fuses, i think. At least I looked at them. I had to have windshield removed & reinstalled. Before that they were OK. Could that be a coincidence or related????? Ideas, before I trounce of to the dealership?
    Toronto, Canada
    BMW 850CSi
    Funny because mine started doing this again this week...
    When you depress the stalk, do they go through 2 strokes (instead of 1) but still stay up at ~15 degrees?
    Try resetting the 3 small green relays at the back of the box. Or switch them around since they’re the same. And/or reset fuse #1. Got mine to park eventually.
    Maybe a GM problem? Mine’s still virgin.
    Nov 2005
    Langley BC Canada
    91 850 Panzer
    Replace fuse 15 and report back
    91 850 (Panzer), 2012 Mini Cooper Countryman (WifeMobile) www.wuffer.ca
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Fuses fine. Looks like it was a K36 relay issue. I had switched them before but may have put the defective one back in. This time I switched with another, it now parks. Do you buy relays by color?
    Sent from my SM-G930V using Tapatalk
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Quote Originally Posted by Dr. T View Post
    Why do the wipers park after sitting overnight, when they would not prior? What "box" are you referring to and how do you reset the relays?
  1. New E30 with old problems
    By smashervt in forum 1983 - 1991 (E30)
    Last Post: 02-12-2016, 03:38 PM
  2. New Idea on OLD problem 318ic
    By Tjandra1972 in forum 1991 - 1999 (E36)
    Last Post: 11-27-2009, 09:20 PM
  3. new vanos, same old problems
    By Erik16 in forum 1999 - 2006 (E46)
    Last Post: 12-04-2007, 09:32 PM
  4. New guy woth old problem (colling system)
    By HomerJaySimpson in forum 1991 - 1999 (E36)
    Last Post: 11-30-2006, 05:34 PM
