Symptoms:
1) Turns over fine
2)Has fuel at the rail and spark but no start
3)Tach bounces all over the place randomly when key is in start position. Doesn't do this while engine is turning over.
Done so far:
1) Spark plugs replaced
2) New crank sensor
3) New fuel pumps (In tank and in-line)
4) Main relay replaced
I don't know where to look next
Moved to E23 forum
How long has this been sitting?
Also, you have one massive paragraph. Break it up for us, it is entirely too difficult to read.
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
Its been sitting for somewhere around five years now. Ive been tinkering with it fixing what I have found that doesn't work and trying to track down the last issues.
In summary: Its a 1985 e23 that doesn't run. It definitely has spark and has fuel at the rail. It turns over just fine when I turn the key but wont start or sputter. Ive replaced the crank sensor and done fuel pump and line replace/repairs. I suspect the ECU but don't really have evidence to back it up so I'm not going after it yet. I don't know what else to check. More symptoms and information ^^^
Thanks.
Hit each injector with 12V. Seen it many times, they could be stuck shut internally. ECUs die and pretty much always stop providing spark. You have this. Hell, spray in starting fluid.
Car will NOT run without both reference sensors functioning on the bellhousing. One is a TDC marker and one is for engine speed. Make sure you have a good CTS.
I make E23 parts.
10/1984 745i
11/1984 745i
Have a friend crank it for you while you hold a screwdriver up to each injector (with your ear at the butt end) to see if they click.
I’m willing to bet the injectors are gummed up or not firing.
Outside of that, make sure you don’t have any massive air leaks. Worst case get a compression test done.
When your enemy is making a mistake, do not interrupt him.
Update: Ive run 12v through each injector and got a nice click from each of them. Trying again a few times to start it, nothing seems to have changed. I double checked the live wires to the main relay and the fuel pump relay and both were good for both relays.
You sure the main relay is good and has correct dual 87 outputs? The green wire is the switched 12V trigger from the ignition switch and the outputs are the dual 87s which are red/blue and red/white. Can always jump the center three pins to verify the wiring is good.
If you are sure you have spark, shoot starting fluid in the throttle body and see if it lights.
Why did you replace one of the two sensors on the bellhousing? If you have them in the
Battery terminals tight AND CLEAN? Is it fully charged and newer?
I make E23 parts.
10/1984 745i
11/1984 745i
Ill test the main relay wiring again in the morning. It activates the new relay when I plug it in and everything down the line from it (**that I have checked) has the correct power etc..
I replaced the sensor because I read that it was a common failure point in these cars and the one that was in there seemed to have been abused when someone tried to take it out and eventually gave up.
I bought a new battery for the car right about a year ago and the connections are all solid and clean to it. Ive had it charged and tested a couple times over the last month most recently was the day I posted this original request for help.
After verifying the main relay wiring is doing what it should Ill use some starter fluid. Ill update after that.
I've found an issue. First of all, I removed the front right speaker and found the relay there to the motronic control was all nasty and rattles. I went to the auto parts store to find a replacement (it seems to be the same exact relay as the main relay). The only ones I found have the same diagram, but the 30pin and the 86 pin are flipped.
I went back to the main relay that I replaced and found that it is flipped as well with the same diagram.
Could anyone with this vehicle tell me the locations of the pins on their main relay?
PM me with your cel number and I will text you a few pics.
Center three pins on the main relay are the 30 and dual 87s. Just jump these and see if the car starts.
Kickpanel relay is for the EH trans.
I make E23 parts.
10/1984 745i
11/1984 745i
