Hey y'all.
I just received my MaxPSI Intake Boot and it's super sturdy, but I'm curious about everyone's fitment to the throttle body. Mine doesn't fit snugly at all on to the TB, and I'm not sure if people just put a hose clamp on there and call it good?
For context, I have an M50 throttle body
Here's a picture of it sitting offset on the TB to show how much slop is in it.
Sent from my Nexus 6P using Tapatalk
'95 E34 525i, M50B32 (S52 Crank, K1 Rods, JE 9.0:1 Pistons, S52 Cams, Cutring, Achilles Oil Pump Shaft & Sprocket), GTW3684R 0.82A/R, ZF320
I use the Mishi stock style silicone boot. Fits snuggly, just blocked one of the two ports on the bottom off
But no it should fit flush and I wouldn't trust that. I would landline max psi and ask and see what they say. I think they have decent customer support - Or you could get a rubber grommet to go around the TB to fill the space.
I use grommets from spectre T bolt clamps (advance auto) on the 3 inch side of the mishi boot because I had the same problem. The seal is almost 'too' good with it:
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Heres a pic of mine
Their number is 908 290 3571. Open monday at 9am. Mike will address any issue you may have.
I'm here to report back that the guys at MaxPSI informed me that the fitment was normal since the throttle body is a hair smaller than 3". They advised that we just use a t-bolt clamp to hold that sucker on.
