Look a little closer, all plastic parts are supposed to have an indicator as to type of plastic used. BMW pretty good about that recycling stuff, made quite a point of it some years ago. You may not realize what the type of plastic code looks like, some are not as obvious as "ABS" etc., using numbers, so a little research should turn up various codes used, then you can look for them.
Alternatively, post the markings you find and possibly someone will interpret them for you.
Charlie
Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
