Results 1 to 25 of 26
Thread: FS: Steel toothed wheel + enforcement bush for electric rear sunshade
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Pics: http://de.tinypic.com/usermedia.php?...c#.VOqDO2ccSUk http://de.tinypic.com/usermedia.php?...c#.VOqDjGccSUk
    Details about installation etc here: http://www.bimmerforums.com/forum/sh...-made-of-steel
    Made to replace the weak original "plastic" toothed wheel which usually loses the teeth over the years and then the rear sunblind starts to rattle and is often inoperatable. That is the large one of the 2 inside the gear. Used in all E32, E34, E31 and even E38 till 1996 for sure, even some till 1998, also some Benz and Audi 5000 models.
    Note: I can only deliver the toothed wheel in version with HEX bolt, not the torx version, which was introduced from 1996 on in E38 and others (no definitive clear cut of change known as even in some 1998 models the hex version was used, so please check your rear sunshade motor), see here the 2 different versions http://de.tinypic.com/view.php?pic=1...7#.XFl0h--P6Uk
    Shipped by SAL from Japan US$65.00 (usually takes about 2-3 weeks for example to the U.S., non-trackable, non-insured). Alternatively shipped by registered air parcel, plus $10.00. Optional enforcement bush $ 8/piece.
    Please contact me by PM with complete shipping address and requested shipping method and I will let you know my Paypal details.
    Hint to extend the life of your original gear: disassemble it, remove all the old hardened grease and fill it with new grease and make sure that also the mechanical parts of the sunshade system are well greased and run smooth.
    Oct 2008
    Madrid - SPAIN
    850iA - 1990
    Just got them.
    Thanks Erich !!!
    Mar 2011
    Alpharetta GA USA
    '97 850 M73 / '90 750il
    Shogun, is that part for the Elec or manual rear sunshade ? I have the manual shade on my '90 750il
    and a couple years ago I pulled mine up and it stayed out and will not retract !!
    kind of a mess actually....
    Jay
    Jan 2005
    Japan
    The steel toothed wheel is for the electric gear/motor unit of the rear sunshade. In case of a manual gear you have to remove the sunshade and check the spring inside. There is a DIY info on my website under fixes>>blinds>>"Rear side window quartershade will not retract fully". You have to 'rewind' the spring. Same procedure for the rear, rewind the spring.
    Electric Roller Sun Blind for Rear Window BMW 5 Series E34, BMW 7 Series E32 , EBA – 01 29 9 787 547 BMW Installation Instructions https://bmweba.com/eba-01-29-9-787-547/
    damaged original toothed wheel
    http://www.wokke.de/BMW-E31-850Ci/Su...nd-gear_01.JPG
    http://www.wokke.de/BMW-E31-850Ci/Su...nd-gear_02.JPG
    http://www.wokke.de/BMW-E31-850Ci/Su...nd-gear_03.JPG
    May 2015
    rotherham
    BMW E31 850 csi 1993
    Hi Shogun
    All my bits have turned up to day Thanks
    James
    Rigel 7
    M3, 850i, E30T, E55T
    Just did this myself with the new gear and brass bushing. You do need to be fairly exact when drilling out the hole for the bushing.
    I found my motor was still having issues getting the blind past the 2/3 point, so I took it out, loosened and refit the aluminum bars, lightly greased the rails and it moved much more freely then. Mine had been broken for quite some time even from the previous owner so it probably seized up slightly.
    Jun 2003
    Toronto
    e24, e31, e32, e39, e60
    Questionl:
    Mine works, however it,when lowering, it makes a grinding noise for a few seconds after shade is all the way down, however it doesn't do it when going up. Will the parts you're selling repair that?
    ['07 BMW M5/6.:Indianapolis Red/Black:.
    Toys
    '93 BMW 850i J Spec- (DiamondSchwartz)-CSI Kit- Lowered-Wokke Chips- Custom Exhaust- 18" MK1's-KN Filters+ M Steering Wheel- Stereo Upgrade +++
    94 BMW 850 CSi - OE
    91 BMW 850Ci Manual
    '88 BMW 635CSi ACS's++
    '81 MB 500 SEC Koenig (pearl white)
    00 BMW 750iL J Spec- Alpina Mods
    06 MB S65 AMG
    09 911 4S
    11 BMW M3 DCT Competition
    12 BMW 328i M Sport Convertible
    Jan 2005
    Japan
    The motor control unit of the sunshade works by increased amps with a delay to stop and most probably you hear it grinding because some teeth are gone and the motor is still trying to move the shade down, because there is a delay time to switch off.
    But to be sure, open the gear up and check the toothed wheel.
    Wiring diagram of the control from E32 http://www.e32-schrauber.de/bmw/date...nshade_mod.jpg
    http://www.e32-schrauber.de/bmw/date...img0368mod.jpg
    Ireland
    X5M E70 and E28 525i
    Hi Shogun, any chance you could reply to my thread and LMK if you think I need a new steel wheel for the electric blind or if my blind itself is the problem?
    http://www.bimmerforums.com/forum/sh...light=sunblind
    Jan 2005
    Japan
    Might be just a matter of bent frame of the blind or lose screws, or old hard grease. I replied there too, here the most important from a Technical Service Info to the workshops on that subject, translate that:
    Technische Info VK-23 Pollatschek Group: 51 511642000 02.05.97 Sonnenschutzrollo der Heckscheibe defekt E31, E32, E34, E36, E38, E39 Beanstandung: Elektrisches Heckscheiben-Sonnenschutzrollo ohne Funktion.
    Ursache: Getriebezahnrad im Sonnenschutzrollo-Antrieb beschaedigt beziehungsweise Lagertoleranzen im Antriebsmotor
    Maßnahme:
    1. Pruefen, ob das Gestaenge in einwandfreiem Zustand (nicht verbogen) ist. Achtung: Der Antrieb darf nicht (!) betrieben werden, solange er nicht komplett mit dem System verbunden ist.
    2. Bei verbogenem Gestaenge kann derzeit nur die gesamte Einheit ersetzt werden.
    3. Bei einwandfreiem Gestaenge ist nur der Antrieb zu ersetzen. Wichtig: Beim Antriebswechsel unbedingt die Einstellung der Zugstangen beachten beziehungsweise wie folgt einstellen:
    - Lager an den Zugstangen durch neue Lager ersetzen.
    - Antrieb auf Motorplatte auflegen und mit 3 Schrauben ansetzen - nicht festziehen!
    - Antriebsscheibe mit Zugstangen auf Antrieb auflegen.
    - Auszugsprofil von Hand herausziehen, bis die Verzahnung der Antriebsscheibe im Abtriebsstern des Antriebs einrastet.
    - Antriebsscheibe am Antrieb festschrauben.
    - Spannungsversorgung herstellen und Rollo ganz ausfahren.
    - Im ausgefahrenen Zustand die 3 Schrauben an der Motorplatte festziehen.
    - Pruefen, ob die Hebelarme gleichmaessig einfahren. Die ersten 10 cm besonders beachten.
    - Gegebenenfalls die 3 Schrauben loesen und Antrieb nachjustieren. Zum Beispiel linker Hebelarm faehrt frueher los - Antrieb nach rechts schieben, rechter Hebelarm faehrt frueher los - Antrieb nach links schieben.
    - Die 3 Schrauben am Antrieb festziehen.
    - Nochmals pruefen, ob die Hebelarme gleichmaessig einfahren
    Nov 2015
    FRANCE
    BMW 850I 1991
    Thank you Shogun for your fast delivery !
    Item is...on the electric rear sunshade mecanism, the electric rear sunshade is on the 850i and after some ajustements, it works...perfectly !
    Reunion Island is a little paradise with five or six 850 ! :-)
    Dec 2014
    Spartanburg s.c.
    91m5
    Shogun, considering your gear and bush,
    there is something wrong with this sun blind, ( Won't go up or down) it really look good
    inside gear housing, the worm spins fine so that's good.
    i tryed turning that lil brown wheel its seem tight but who knows, anyway do you have the small brown gear? Too
    my large wheel is made of metal, I do see a small area like 5 spline with lil stwist.
    thats in advance
    Jan 2005
    Japan
    Maybe the control unit is the problem. See here the ETM section http://www.e32-schrauber.de/bmw/date...nshade_mod.jpg and some info in German language http://www.e32-schrauber.de/bmw/s-heckrollo.htm
    The small brown gear I do not have, only the large one with hex nut. For the small one there is almost no demand, maybe once a year someone is asking.
    Oct 2008
    Madrid - SPAIN
    850iA - 1990
    Please, could you PM me the payment details for another set ( toothed wheel + enforcement bush ) to be sent to Madrid ( another E31 from 1990 )?
    Thanks !!!
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by shogun View Post
    @Bimmerchris89: 1 x toothed wheel shipped to Fredericia, Denmark
    @Ralf: 1 x toothed wheel +enforcement bush shipped to Cologne, Germany
    @Andreas: 1 x toothed wheel shipped to Munich, Germany
    @Simon: 1 x toothed wheel + enforcement bush shipped to Kirchzell, Germany
    @andjelo: 1 x toothed wheel + enforcement bush for your 1992 Bmw 850ci sent to Solin, Croatia
    @Dirk, 3 toothed wheels for E31 send to Schloß Holte - Stukenbrock, Germany
    @Andreas: 1 x toothed wheel + enforcement for your E31 bush shipped to Braunschweig, Germany
    @CaifanSC: toothed wheel plus enforcement bush on the way to Laurel, MD
    Received mine last week Shogun, thanks!
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
    Oct 2008
    Madrid - SPAIN
    850iA - 1990
    Have received mine today.
    Regards
    Nov 2015
    Turku - Finland
    1991 850i 6 Speed
    Quote Originally Posted by Gmoney19 View Post
    thats in advance
    You can drive the unit directly with + & - to the motor but be carefull and if it does not start to move remove the leads.
    Jul 2016
    United Kingdom
    1992 BMW 850i
    Many thanks toothed wheel and bush arrived safely, much appreciated.
    Kind Regards,
    Barry
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Yes, thank you. It was a fast delivery about a week from Japan to Sweden.
    Nov 2008
    Maryland
    not enough
    @Rainer: 1 steel toothed wheel for the electric sunshade in your Mercedes Benz W 124 500E (same gear/motor unit as in our BMW) shipped to Lohne, Germany
    Shogun, any idea if the wheel fits the sunshade from an 03 Audi S8? I have to diagnose a recent issue with my sunblind but just in case I wanted to ask.
    My other projects:
    Jan 2005
    Japan
    To be sure, you will have to check and disassemble what is inside the gear. 2003 Audi is probably the newer version, which I do not have. Audi, Mercedes Benz of similar built years like our E31, E32, E34 and some early E38 had the same gear and motor maker. BMW changed to the other version gradually from around 1996 with the E38, but even sonetimes E38 from 1998 have the older version like in E31. I can only deliver the toothed wheel in version with HEX bolt, not the torx version, which was introduced from 1996 on in E38 and others, see here the 2 different versions http://tinypic.com/view.php?pic=1jrztz&s=7#.WL-AKO_auUk
    It is not only a difference of torx or hex bolt, also the teeth angle is different, see here, new http://tinypic.com/view.php?pic=2mcs...7#.WL-A2O_auUk
    I was told my steel version fits for Audi gear p/n (4A0959733) to replace the weak original toothed wheel such as for example (European type mentioned, please check the type description in your country)
    Audi 100/S4 (4A, C4) (1991 bis/till 1994)
    Audi A6/S6/S6plus (4A, C4) (1994 bis/till 1997)
    Audi V8 (4C, D11) (1989 bis/till 1994)
    Audi A8/S8 (4D, D2) (1994 bis/till 1999)
    Audi quattro
    Nov 2008
    Maryland
    not enough
    I recall the post where it was confirmed that the Audi D2 sunshade used your gear. This car although 2003 is still considered a D2...but I will have to confirm. If I pull the sunshade to fix my problem I have the gear I bought from you to confirm fitment. I have both the audi v8 and S8 so I was planning on buying some more gears from you at some point .
    My other projects:
    Jan 2005
    Japan
    Let me know your findings, as I can only check the internet and do not have the real Audi, VW or Benz parts at hand, so I only supply to those people and often they just order and do not tell me the exact model, just word of mouth in their forums that my toothed wheel fits. I checked with Audi p/n above and audiusa website mentions: MOTOR #: 4A0959733 $ 321.30: fits 15 vehicle variants: 2 models, 15 variants between 1998 - 2003. Audi A8 3.7L FWD Base 1998/99, Audi A8 4.2L AWD Base Quattro 199/9, Audi A8 Base Quattro 2000/1/2/3, Audi A8 L Quattro 2000/1/2/3, 2003, Audi S8 Base 2001/2/3. http://www.oemepc.com/audi/part_sing...9015/part_id/0
    German spec: VW Sonnenschutzrollomotor #: 4A0 959 733 respect. 4A0959733, fits for: AUDI 100 (C4) 1991 >1994, AUDI A6 (4A) 1995 >1997, AUDI A8 (4D) 1994 > 2002, AUDI A8 (4E) ab 2002 > 2003, AUDI V8 (4C) ab 1989 >1994.
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Everything is installed and working perfectly!
    Thanks again for quality parts.
    Jan 2005
    Japan
    @Rainer: 1 steel toothed wheel for the electric sunshade in your Mercedes Benz W 124 500E (same gear/motor unit as in our BMW) shipped to Lohne, GER
    @Helge, 1 x steel toothed wheel + 1 enforcement bush for your 1992 E31 850 shipped to Aalesund, Norway
    @dancerst: Toothed wheel + enforcement bush for your 840 shipped by registered airmail
    @Matthias: 1 x toothed wheel + enforcement bush for your Mercedes Benz W124 shipped to Hamburg, GER
    @Joachim: 1 toothed wheel shipped to Duisburg, GER
    @*Sándor: 1 toothed wheel shipped to Budapest, Hungary
    @Thomas: 1 x steel toothed wheel + enforcement bush for your E34 540 shipped to Hamburg, GER
    @Oliver: 1 x steel toothed wheel + 1x bush for your Audi A6 A4A built 1995 shipped to Burg
    @Klaus: 1 x toothed wheel + enforcement bush for your E32 750iL shipped to Floersheim
    @Oli: 1 x toothed wheel for your E31 850 shipped to Diez, Germany
    @DeltaSix: 1 x toothed wheel + enforcement bush shipped to Victoria BC
    Last edited by shogun; 07-27-2018 at 04:45 AM. Reason: shipping info merged over a longer period
  1. Replies: 13
    Last Post: 05-25-2020, 10:17 PM
  2. FS: Steel toothed wheel + enforcement bush for electric rear sunshade
    By shogun in forum E34 Classifieds (closing soon)
    Last Post: 02-22-2019, 08:09 AM
  3. Electric Rear Sunshade Measurement
    By gleech in forum 1996 - 2003 (E39)
    Last Post: 07-24-2011, 04:35 PM
  4. E34 FS: M30 turbo manifold, Mitsu Tdo4 13t turbo, Rear sunshade ect...
    By mrsharp in forum E34 Classifieds (closing soon)
    Last Post: 10-08-2009, 02:11 PM
  5. Electric rear sunshade?
    By moroza in forum 1988 - 1994 (E32)
    Last Post: 08-24-2009, 09:41 PM
