Bavarian Soundwerks
Results 1 to 3 of 3
Thread: 1986 325e Power Problem
    Jul 2018
    Kingsland, GA, USA
    1986 BMW 325e
    Did a gas pedal bushing replacement, disconnect throttle line, replaced it, put everything back as I found it and this occurred:
    Put the key in the ignition, pressed clutch and pedal all the way in, had the shifter in neutral, turned the key, full lights inside of the car flashing check engine light (as normal?), everything lights up. Go to start it, single click. Did it a few more times, single click for awhile then zero noise. Took the battery to get tested, it tested good, came back home, put the battery back in correctly, checked for a good ground, put the key back in the ignition, same stuff as before, except when I turned it, there were zero lights, and trying to take it to start had zero result.
    Any ideas? Looked under the dash, doesn't look like I disconnected any wires while doing the bushing replacement. If I need to go test something, let me know, I'll do it to the best of my ability. This is my first project/manual car, so I'm still learning. Thanks in advance!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    It sounds like the battery is bad. How was it tested?
    Jul 2018
    Kingsland, GA, USA
    1986 BMW 325e
    Quote Originally Posted by MarcoZandrini View Post
    I took the battery to advanced auto parts and they tested it.
  1. 1986 325es- With Problems
    By pcoote in forum 1983 - 1991 (E30)
    Last Post: 03-20-2011, 07:06 AM
  2. 1986 325es accel problems
    By midas72 in forum 1983 - 1991 (E30)
    Last Post: 02-01-2011, 05:49 PM
  3. 1986 325e No Power at the coil??
    By frecon931 in forum 1983 - 1991 (E30)
    Last Post: 02-25-2008, 12:09 AM
  4. 1986 325es cv problem
    By pbradford161 in forum 1983 - 1991 (E30)
    Last Post: 07-07-2007, 06:02 PM
  5. Wtb: 1986-87 325es Power Antenna
    By dchoi619 in forum BMW Parts Wanted
    Last Post: 08-13-2004, 05:21 PM
