Originally Posted by
Vinci
245/35-18 will barely clear stock suspension on an 18x8.5 ET43 wheel. The fender clearance is fine with those numbers. I use a 12mm spacer with that configuration and still have acceptable fender clearance. 12mm is just under 1/2", so you just need to worry about your offset.
Do your own math to be sure, but if your offset is around 31mm, you are good. Less offset and your fender becomes a worry. More offset and you could get into your suspension. Also keep in mind that different brands/models of tires vary even with the same size numbers.
