Results 1 to 8 of 8
Thread: Fuel filler door reminder
    San Jose, CA
    1997 BMW 540i 6 speed
    Be sure to periodically check the hinge for cracks. It’s plastic. If it breaks, you’ll lose the door. You’ll need to paint the new one.
    I found it easiest to remove the door to replace the hinge. You’ll need to realign it. Not difficult.
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    A good PSA.
    Also, as a preventive measure, when fueling the car and placing the filler cap into the little cap-holder in the filler door, counter-hold the cap-holder (place equal upward pressure by holding the bottom of the cap-holder) to prevent putting too much strain on the door hinge when pushing the cap into the hole.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Mar 2012
    Hayling Island
    Alpina B10
    Quote Originally Posted by edjack View Post
    Be sure to periodically check the hinge for cracks. It’s plastic. .
    Is that the “Hinge, gas cap” or “spring”?
    Sent from my iPad using Tapatalk
    San Jose, CA
    The hinge is plastic. The spring is steel. The gas cap need only be replaced if the seal or vacuum valve fails.
    Sep 2014
    KS
    e24e30e36e39e90
    Or if you leave it in the gas filler door, take off from the gas station and start driving up the on ramp to the highway, and look in your mirror just in time to see it bouncing down the shoulder and off into the weeds.
    Mar 2012
    Hayling Island
    Alpina B10
    So where does the hinge break, where the pin pivots?
    San Jose, CA
    IIRC, it broke at the steel pin.
    But is easily noticed, if you carefully examine it.
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    Quote Originally Posted by sienayr View Post
    Or if you hear something go "klunk" and don't realize it's gone until the CEL comes on.
  1. Fuel Filler Door issue
    By paul e in forum 1992 - 1999 M3 (E36)
    Last Post: 04-22-2007, 11:41 PM
  2. Fuel filler door broken & door panels warped
    By backindauk in forum 1988 - 1996 (E34)
    Last Post: 12-05-2006, 11:11 AM
  3. Fuel filler door...water inside...draining?
    By SeanMpower in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-23-2006, 11:26 PM
  4. How to remove fuel filler door?
    By NLR in forum 1992 - 1999 M3 (E36)
    Last Post: 03-27-2006, 01:33 AM
  5. Latch on Fuel Filler Door Missing?
    By rnishman in forum 1988 - 1996 (E34)
    Last Post: 06-26-2004, 01:35 AM
