Results 1 to 25 of 28
Thread: ASC light always on. What could be the problem?
    Iceland
    BMW 850
    Hey guys. I am having a problem with my ASC light as it is always on.
    Only the ASC light and I cant turn it of with the button.
    What should I look into?
    Nov 2009
    Las Vegas, NV
    95 840ci 6sp,00 750iLV12
    Mine does it sometimes. I think it's related to voltage or the unit possibly on its way out. Normally happens on a restart from the daily run, never on the initial cold start
    Sent from my SPH-L720 using Tapatalk
    San Jose CA
    1991 850i S70 6 speed
    Are you getting anything on your MID/OBC? I had the speed sensor (expensive) break off. Driver side, if I recall correctly.
    Quote Originally Posted by Fatandre View Post
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Look into:
    - wrong size wheel and tires (they can't be more than 3% different between front and back)
    - dirty/broken speed sensor on each wheel
    - failed ASC+T Hydro pump (if your car has ASC+T)
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Iceland
    BMW 850
    Quote Originally Posted by TxGR8White View Post
    Look into:
    Just to be clear its only the ASC light
    I have asc T
    It also happens with stock wheels and tires.
    Dec 2007
    Dallas, TX
    Your ASC+T Hydro Pump has failed - good luck, those are hard to find.
    Sep 2009
    Huntington, NY
    94 BMW 840Ci
    Has this car been sitting for a while? Mine did this after sitting a few months, and the "fix" was to drive through a couple puddles enough to (I assume) clean the crap off the wheel sensors. I think rust had built up on the rotors while sitting, and when I took it out for the first time after that all of it got scrubbed off and ended up on the wheel sensors.
    San Jose CA
    -Mine was: broken speed sensor
    failed ASC+T Hydro pump (if your car has ASC+T). I have one on my parts car, but someone called DIBs already. If they don't come through, I will let you know.
    Look into:
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    Check the ASC cable. My cable had frayed and that caused the cable to 'stick', and made the ASC light come on.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Give it a poke - they usually get going again:
    My BMW Repair YouTube Channel
    Iceland
    BMW 850
    So i should Just make a hole in the relay and poke it with a screwdriver ?
    Dec 2007
    Dallas, TX
    That is like asking if you should jam a screwdriver through the fender into the Hydro pump and see if it fixes itself - we narrowed it down for you. You now need to do actual diagnosing on your vehicle and find the problem. When I had this problem 10 years ago, I narrowed down to the Hydro Pump and had to pull it and replace it. You can check the 4 wheel sensors pretty easily. The sensor itself rarely fails, but you need to look at the wiring too. Usually it is just dirt build up on the magnet - clean them off and see if the light goes out. If it doesn’t, then you will most likely need a new ASC hydro pump.
    Iceland
    BMW 850
    Quote Originally Posted by alex840 View Post
    Let me know
    Did how is your csi ?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Ooohhh! That's a bit of a slight for us Shadetree mechanics! But I also realize that you have an early 850, so the relay is not where it is on the 840 anyway....
    Jul 2017
    toronto, ontario
    1991 BMW 850i
    Suggest check asc codes and go from there (http://www.bimmerboard.com/forums/posts/213216).
    Dec 2007
    Dallas, TX
    Fatandre has an 850....
    Orlando, FL USA
    On my car, the MID displays the "Brake Assist" message and "Check" message. The cluster shows the (!) indicator. It comes on and goes off on a regular basis.
    The funny thing is, every time when I flip the headlights, the "Brake Assist" message and (!) lamp on the cluster comes on right away. I had a leak in the pentosin system that I have recently fixed and have bled the system via the valve by the shock tower on driver's side.
    The brakes are very mushy so I need to bleed the brakes. Not sure why turning on the headlights would trigger the Brake Assist warning to come on the MID.
    St.Petersburg, Russia
    KS
    Fatandre, start the ASC self-diagnostic.
    I've read the manual, it was pretty easy.
    It will blink on the dash, and you'll see.
    I don't remember, you need to turn ignition with ASC button pressed for 10 seconds or something like that.
    In my case, a very odd one, the system did not like the ASC+T/ABS control module. So it blinked to the last error - control module.
    Everyone told me it must be an ASC+T pump. Nevertheless, I bought a spare ASC+T/ABS control module, installed and it was fixed.
    The fun thing that the ASC module didn't answer to normal service tool diagnostics via the round plug. So self-diagnostics works!
    p.s. For your interest, I've opened up the ASC+T/ABS module and it looked scary and perfectly fine. The scary thing is that there are many gel-celled processors, and it's all "made in Austria" which you don't see often.
    Iceland
    BMW 850
    Thanks Diskovod.
    How do you read the blinking?
    KS
    Here are the instructions
    https://imgur.com/a/hWxkyaZ
    Please, save the images, it's likely they won't last forever, and they exceed bimmerforums size quota.
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    sadly I replaced my tandem pump for my ASC+t system and it seemed to fix the ASC+t light form coming on for months, then again it came back.
    I'm looking to see why its back.
    Have you bled your pentosin system properly by disconnecting the ABS module connection then bleeding the ASC+t nipple back into pentosin reservoir? I just did it again and it definitely helped make my steering groan a lot less again and braking somehow seems a little crisper, but still did not solve my ASC+t light, which comes on only after the car heats up. Never on a cold start.
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Self Test diagnostics
    '91 850i 6sp (mint) (sold)
    Nov 2013
    Whitney, TX
    97 850CI
    As if an 8 needs ASC+T. I can't imagine a driving condition when it would be necessary. I am considering disabling mine.
    Desecrator of all things Sacred
    Calgary, Canada
    sadly, my 03/90 build will not connect and allow INPA to perform this test.
    Iceland
    BMW 850
    What is it that gets damaged in the ABS- ASC T unit?
    They are pretty hard to source
  1. asc light always on??
    By ZorNotToZ in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-27-2012, 04:45 AM
  2. 1994 530iA ASC light always on, late shifting
    By 94530inh in forum 1988 - 1996 (E34)
    Last Post: 10-12-2008, 11:29 PM
  3. 1994 530iA ASC light always on, late shifting
    By 94530inh in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-11-2008, 11:19 PM
  4. Help - ABS and ASC lights still on - always on
    By marcoyukon in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-27-2008, 10:00 AM
  5. asc light always on
    By lilmadherb in forum 1996 - 2003 (E39)
    Last Post: 08-23-2007, 04:20 PM
