Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 81
Thread: Another LS Swap... 1994 325is 4.8 build!
  1. #51
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Good to see you did the valve covers, they look nice. I need to do mine, probably the same color as the car, if I can decide what that color is going to be.
    Can't help you with the shifter, I'm using a 4L65e tranny.
  2. #52
    Nov 2018
    Florida
    E36 325is Coupe
    Love this build so far... plan on doing mine when the time is right.. Are you using stock ECU from the truck or a stand alone? Do you know round about what you've spent so far or not keeping track?
  3. #53
    Canterbury, CT
    1995 BMW 325i
    Stock ECU, and I got the motor and trans for “free” (traded some labor), mounts and headers for about $1k, about $1500 into the motor for all the parts and machine work, $300 worth of nick nacks, brake lines, prop valve, P/S block off, paint materials, I had the paint laying around I don’t have a price on that, $2400 for the trans, and I’ve got another $1300ish worth of things to buy to button it up, plus running stock ECU with HPTuners so another $400 for the MPVI2 with credits. I’ll round about $7k-7500 total?
  4. #54
    Canterbury, CT
    1995 BMW 325i
    Bored and waiting on parts to get delivered... might as well polish up the bellhousing since you maybe might see a little bit of it in the bay.
  5. #55
    JimLev's Avatar
    Sundance Mesa, NM
    Might look good sprayed with some gold .
  6. #56
    Mar 2011
    PNW
    LS E46
    Quote Originally Posted by eturdysix View Post
    What is that paint? I can’t believe how deep the color is
  7. #57
    Canterbury, CT
    1995 BMW 325i
    Quote Originally Posted by Liquidity View Post
    Duplicolor engine enamel with duplicolor engine gloss clear! I was going to spray it with some BASF stuff we had laying around but this is probably a one-year motor before it goes into something else and gets replaced with bigger power.
    Thought about it but I don’t wanna go overboard yet. Bolts, alternator bracket, and some other stuff will be polished/billet and I cleaned but didn’t paint my brake master so it might work out to give it some shine.
    On another note... ordered absolutely everything else I need from clutch to accessories to tuner, except for mufflers and a driveshaft (going to get a measurement and call local... I don’t see spending $700+shipping on a vorshlag being anywhere near as cost effective). Two weeks or less til first start maybe!? I’ll build the exhaust after, will be running 2.5 duals all the way back with an x pipe and more than likely two race mufflers on the ass end. Sorry boys but I’m doing duals out the back not the stock single sided dual tip BMW setup. Need a little bit of american muscle look on the outside!
  8. #58
    Mar 2011
    PNW
    LS E46
    FleetPride can do up a nice driveshaft for around $250-300. $700 is total nonsense. How much power do you plan to have eventually? 2-1/2 might even be overkill. Dual 2-1/4” outflows a single 3” by over 10%.
  9. #59
    JimLev's Avatar
    Sundance Mesa, NM
    Duals out the back will look good.
    I'm doing the dual tip (M5 look) on each pipe.
  10. #60
    Canterbury, CT
    1995 BMW 325i
    2.5 is overkill... but I have a c5 vette dual mid/x pipe setup that with minimal modifications (and welding on some v bands) will perfectly fit up to the headers and clear in the tunnel, all I’ll have to make it the rest out the back. No biggie. And free! And remove 4.8 and add 408 stroker is next winter plans if the car lasts that long hahaha.
    Anyway. Shipment 1, got some done. waiting on some other stuff!
  11. #61
    Canterbury, CT
    1995 BMW 325i
    LSX Innovations makes some good stuff. Time to drill and tap the block! May the beer gods wish me straight drilling tonight hehehe
  12. #62
    Canterbury, CT
    1995 BMW 325i
    Beer gods were good to me!!!! Power steering-less accessory drive complete!
    Slave cylinder also in! Using speedway remote bleeder kit and punched out the roll pin and put in -3 AN adapter fitting. Motor and trans will be in tonight!
  13. #63
    JimLev's Avatar
    Sundance Mesa, NM
    Looks like your making good progress.
    Have you checked the Max RPM of that alternator?
    Mine said not to exceed 18K RPM. With my pulley ratios with the engine at 6600 redline the alt would be spinning at 24K RPM.
    I bought a bigger diameter alt pulley to slow it down.
  14. #64
    Canterbury, CT
    1995 BMW 325i
    Yeah no idea. Gunna run it and hope for the best it has a warranty. Mo pictures. Just for the record the MGW shifter is absolutely insane and I love it.
  15. #65
    JimLev's Avatar
    Sundance Mesa, NM
    Good fit.
    I had to pull the heater hose fittings out, tap the holes and install 45° fittings, not enough room to make the bends without kinking the heater hoses.
    Bought an adjustable pump outlet for the lower radiator hose too.
  16. #66
    Canterbury, CT
    1995 BMW 325i
    Good fit.
    I may have to follow suit. Tight fit down there!!
  17. #67
    Canterbury, CT
    1995 BMW 325i
    She’s alive!
    https://youtu.be/FvuaY3oI2Sw
  18. #68
    JimLev's Avatar
    Sundance Mesa, NM
    Nice big cam idle, love it. Don't cork up that exhaust too much.
  19. #69
    Canterbury, CT
    1995 BMW 325i
    Y pipe to 3” strainless all the way back. No mufflers or resonators in the plan. BUT I plan on putting a v band on the back side of the rear diff and having a straight pipe or possibly race muffler depending on the tone I get and a “im gunna drive this to work and don’t wanna wake the kiddo up” muffler that’ll use the v band and same exhaust hanger so I can swap it out in minutes without jacking the car up.
  20. #70
    Apr 2012
    Stuttgart, Germany
    1997 M3 / 5.3
    That is a big hurdle! Congrats.
  21. #71
    Mar 2011
    PNW
    LS E46
    Love the lope. What cam did you run?
  22. #72
    Canterbury, CT
    1995 BMW 325i
    Its a new summit grind, 8708. 231/242 113+3 .600/.600
  23. #73
    Mar 2011
    PNW
    LS E46
    That’s a healthy cam! I heard summit has a new guy redoing their whole cam lineup, I’m curious how this runs. When is it going to the dyno?
  24. #74
    Canterbury, CT
    1995 BMW 325i
    Should be road worthy in another week or two so sometime soon after that I’d say. I heard the same and for the price risked it. 8708 and up cams are the new design
  25. #75
    Canterbury, CT
    1995 BMW 325i
    Getting there! Remaining list is repaint fuel rail, finish wiring harness, finish cooling system, make an intake, wire in the fan, put the front end together, break in and tune, lots of burnouts.
  1. Engine swap: 1994 325i or 1996 328i for my 1995 325i
    By jjj624 in forum 1991 - 1999 (E36)
    Last Post: 08-24-2015, 10:56 PM
  2. Swapping out DME on 1994 325is
    By epexen in forum 1991 - 1999 (E36)
    Last Post: 04-19-2006, 10:59 PM
  3. 1994 325is, Digital Climate Swap Complete!
    By mpower325 in forum BMW Rides & Events
    Last Post: 01-31-2006, 05:00 PM
  4. 1994 325is manual trans swap
    By M34life in forum 1991 - 1999 (E36)
    Last Post: 05-07-2003, 03:36 PM
  5. E36 - 1994 325is M3 Transmission swap
    By ComradeLinen in forum 1991 - 1999 (E36)
    Last Post: 03-24-2003, 07:42 PM
