Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 5 of 5
Thread: DS1 Restoration help
    Oct 2017
    Orangeburg, SC
    1999 BMW M3 Convertible
    I picked up a set of ds1 rims recently with a rattle can paint job on them & have started the process of removing the spray. I’m trying to get down to the bare aluminum so I can sand & polish them. The problem I’m having is the oem paint does not want to come off. Would anyone have a recommendation to what products or processe should be used to make this a bit easier? The rims have all been coated with paint remover & scraped twice at this point.
    Jun 2005
    Ventura County/California
    bmw 88m3 bmw 2015X6
    What kind of paint strippers have used so far?
    Oct 2017
    Orangeburg, SC
    I’ve used one spray that didn’t do much of anything and another that I would describe as a goop or paste called klean strip
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    I did a similar stripping job on a set of RC041s. I used Jasco which is effective but contains methylene chloride (nasty chemical solvent with noxious fumes). Klean strip is similar. I took precautions including chemical respirator, long sleeves, nitrile gloves, etc. But honestly, you’re better off paying to have them professionally stripped even if you do the paint work DIY. Those chemical strippers are pretty dangerous.
    Oct 2017
    Orangeburg, SC
    Haven’t had much time to work on them but this is about where they are now:
    This is where they started:
    Hopefully I can get some time off to start sanding
  1. Project Bon Ami glass restoration... help!
    By JD886 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 01-29-2006, 11:42 AM
  2. Replies: 8
    Last Post: 02-12-2005, 07:31 PM
