Results 1 to 15 of 15
Thread: 5x114.3 hubs, what are your thoughts?
    Jul 2015
    Clarkston Wa/Lewiston ID
    96 328i coupe
    I am about due to replace my hubs, found these dual drilled hubs on ebay, they are about $200 more than standard, what are your thoughts on a setup like this? Better off to buy a standard set of hubs and have them drilled and tapped? Buy these and call it good?
    https://www.ebay.com/itm/BMW-E36-dua...4383.l4275.c10
    socal
    330i, 323i
    I wanna read opinions too.
    What wheel would you use?
    I can't find OEM wheels with Bore Diam >= BMW's 72.56mm.
    none
    Jul 2015
    96 328i coupe
    5x114.3 means I could run a ton of different wheels I dont have any picked out at the moment though, getting the center bore to 72.56mm is pretty easy and cheap at any machine shop
    Mar 2017
    NJ
    e36 325ic
    Next time I replace hubs I’ll probably do that. I’ve been running ichiba adapters and they’ve been fine. Most Japanese wheels are 73.1 hub bore.
    There was a guy on here that did hubs in 5x114 that he sold I believe
    Aug 2011
    tampa, FL
    1995 325i
    Those $600 Johnnies are just redrilled ebay hubs .. why not do it yourself with the PBM template, or have a local machine shop do it? Probably be like 1/3 of the cost. I believe he's using these hubs
    https://www.ebay.com/itm/Wheel-Hub-N...LH_TitleDesc=0
    Mar 2017
    NJ
    e36 325ic
    i know some other people in this subforum talked about dual drilling hubs to 5x114 but one of the things is that some of the hubs are like the ones pictures below where the material is thicker where the 5x120 holes are...
    So obviosuly you would want to make sure that if you were to dual drill that the material is the same around the whole hub. I know the hubs I replaced for my front wheels were like the picture I posted, the front was smooth but where the holes were drilled the material was thicker on the back of the hub
    Jul 2015
    96 328i coupe
    With my discount at NAPA just new good quality hubs are $300 and I found a local shop that will drill the hubs and rotors for under $200
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I just don't get it I guess. If you're buying new wheels why not just get them in 5x120? It's not like that's a rare size. With that said I do have a set of Ichiba adapters floating around, but that's because I have about 10 wheels for my RX7 in 114 already
    Jul 2015
    96 328i coupe
    I want to get a set of older split 3 spoke advans, they never made them in 5x120 and with adapters the offset would have to be really high to fit under my fenders. I have a thing for late 90's/early 2000's jdm wheels and those are really hard to find in 5x120
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    ahhh ok that makes more sense than!
    BALTIMORE
    $200 for a shop to drill both the hubs and the rotors isn't a bad deal. I'd reuse my existing rear hubs to save some cash, but that's me
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
    Jan 2014
    San Antonio
    98 328is
    heads up, Chaz from Nerptech will do this for $75 corner if you send him everything (hubs and rotors etc). that price includes press in ARP studs.
    Quote Originally Posted by cody2130 View Post
    lol, i been wanting Super Advans for awhile. theres someone floating around on facebook e36 world that has them. i love it.
    Jul 2015
    96 328i coupe
    Quote Originally Posted by RandomHero27 View Post
    After my first experience with Nerptech I will never do business with him again. I ended up having to file a damn paypal claim just to get him to send me my parts..... 100% unimpressed
    Jul 2018
    CT
    E36
    I joined just to say this. My friend and I are the ones that sell those hubs. They are most certainly NOT eBay hubs as stated by another member. We only use FAG or Febi Bilstein hubs. They will most likely outlast the car they’re going on, hence the price tag. Sure, we could use inferior quality hubs and make it cheaper, but we both feel like something as important as, you know, holding a wheel on the car is not an area we’d cheap out on.
    Jul 2015
    96 328i coupe
    Glad they are a quality unit, glad you chimed in man, thanks for the info!
  1. Replies: 0
    Last Post: 09-10-2013, 12:48 PM
  2. E39 5x114 hub centric 21mm adapters.
    By OJwerks in forum Wheels and Tires
    Last Post: 12-16-2011, 12:26 PM
  3. VAC Steering Wheel Hub/Quick Disconnect: Thoughts?
    By thedizzle in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-28-2010, 09:36 PM
  4. Making 5X114 wheels fit my 5X125 hubs....
    By buck1115 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-02-2007, 03:08 PM
  5. Does any one make a Coversion Hub for e39 to 5x114.3
    By Spark Racing in forum 1988 - 1996 (E34)
    Last Post: 10-05-2004, 03:25 PM
